Anyway, on a Fresh install of Zorin 16 Core (on an NVMe Drive) I'm noticing a slightly odd behavior each time I'm emptying my trash can.
A notification from Files/Nautilus appears saying -> "" is Ready
Those are system notifications; it is letting you know that the nautilus file manager has launched. I find it annoying on Gnome... Especially when I open a large number of instances in Gimp.
You should be able to turn that off;
Ohh, ok I see now, I thought something might be missing in those quotes !
Thanks for the answers.
Edit : I ended up installing Focus my window - GNOME Shell Extensions
Notification is gone and focus seems to be given to the actual window.
I'll be testing this more over the next days.
