GreJan
April 24, 2023, 5:01pm
1
Sorry google translate
Hello everyone,
I installed Zorin OS 16.2 again today after a long time.
Actually everything goes very well except for shutting down and restarting the system it takes forever.
Do you have any tips for me on how to speed it up?
Thank you in advance
Gregory
Storm
April 24, 2023, 9:42pm
2
What's your computer specification?
Storm
April 25, 2023, 5:15am
4
The specs looks fine.
You can hit [ESC] under shutting down/restarting to see what's going on and take a picture of it.
Also you don't use snap I see. It's notorious slowing the system. Youo can uninstall it by:
Greetings,
You're like me don't like Snap for whatever reason(s) and want to remove it from your system? Look no further, this is how it is done.
With two commands you'll be Snap-free. But beware it will uninstall any snap installed application also.
The first command clear the snap cache.
The second command remove snap and snap applications.
sudo rm -rf /var/cache/snapd
sudo apt-get remove --purge snapd
Enjoy!!!
This is very helpful thank you sir.
system
Closed
July 24, 2023, 8:39am
7
