Slow WiFi download speeds for network adapter RTL8852BE
I have 1 gbps network but my download speeds are terrible since I installed Zorin on my Lenova Ideal pad 5
I have tried so much tinkering that now I'm just going to ask Zorin developers to produce a fix. Will you please fix this please?
Hello and welcome,
Try this
sudo nano /etc/NetworkManager/conf.d/default-wifi-powersave-on.conf
and set
wifi.powersave = 2
Ctrl+X , then Y , then Enter
sudo systemctl restart NetworkManager
and test
If you have a Dualboot with Windows please disable fast startup at Windows power management.
Also, please show the terminal output of
sudo lshw -C network
It could be a driver needs to be replaced.
Are Secure Boot and Fast Boot in BIOS disabled? Is this a fresh Install? Or do You use Zorin already a While and this Issue is new?
*-network
product: RTL8852BE PCIe 802.11ax Wireless Network Controller
physical id: 0
bus info: pci@0000:01:00.0
logical name: wlp1s0
version: 00
serial: 9c:2f:9d:b2:c3:db
width: 64 bits
clock: 33MHz
capabilities: pm msi pciexpress bus_master cap_list ethernet physical wireless
configuration: broadcast=yes driver=rtw89_8852be driverversion=6.17.0-35-generic firmware=N/A ip=10.0.0.147 latency=0 link=yes multicast=yes wireless=IEEE 802.11
resources: irq:77 ioport:2000(size=256) memory:fd600000-fd6fffff
One of the first things I tried. Thank you. But it didn't do anything.
It's a fresh install on a previous windows 11 laptop. Secure boot is disabled.I don't know about Fast boot. But on Win 11 the speed was what it should be 800mbps around.
It's not a dualboot.
Found here
Try this
echo “options rtw89_8852be_git disable_ps_mode=y disable_aspm=y” | sudo tee /etc/modprobe.d/rtw89.conf
I tried but the speed is still the same. Thanks for trying.
could you give us the result of
dpkg --list | grep linux-image | awk '{print $2}'
linux-image-6.17.0-20-generic
linux-image-6.17.0-35-generic
linux-image-generic-hwe-24.04
output of this please
sudo grep -E "submenu '|menuentry '" /boot/grub/grub.cfg | cut -d"'" -f2
Zorin OS
Advanced options for Zorin OS
Zorin OS, with Linux 6.17.0-35-generic
Zorin OS, with Linux 6.17.0-35-generic (recovery mode)
Zorin OS, with Linux 6.17.0-20-generic
Zorin OS, with Linux 6.17.0-20-generic (recovery mode)
UEFI Firmware Settings
We gonna try to reboot with an older kernel, do this
sudo grub-reboot "Advanced options for Zorin OS>Zorin OS, with Linux 6.17.0-20-generic"
sudo reboot
That could be something. There is nor Firmware loaded. Driver and Kernel are.
Still the same results with the generic. :disappointed_face:
How do you add the firmware to this network adapter.
ok so we will try to upgrade to liquorix kernel
tutorial from @Aravisian
To use the Liquorix kernel:
Add repository
sudo add-apt-repository ppa:damentz/liquorix
Update sources and install:
sudo apt update && sudo apt install linux-image-liquorix-amd64
Reboot
