Slow WiFi download speeds for network adapter RTL8852BE
Give me the result of
iw dev wlp1s0 link
iw dev wlp1s0 station dump
Connected to fa:d0:0e:3d:d2:72 (on wlp1s0)
SSID: Konawifi
freq: 5785.0
RX: 38566070 bytes (40095 packets)
TX: 45492858 bytes (46631 packets)
signal: -36 dBm
rx bitrate: 54.0 MBit/s
tx bitrate: 54.0 MBit/s
bss flags: short-slot-time
dtim period: 1
beacon int: 100
habanero@habanero-IdeaPad-5-15ABA7:~$ iw dev wlp1s0 station dump
Station fa:d0:0e:3d:d2:72 (on wlp1s0)
inactive time: 4633 ms
rx bytes: 38616772
rx packets: 40342
tx bytes: 45496566
tx packets: 46641
tx retries: 0
tx failed: 0
beacon loss: 0
rx drop misc: 136
signal: -36 [-36, -41] dBm
signal avg: -37 [-37, -41] dBm
tx duration: 0 us
rx duration: 0 us
authorized: yes
authenticated: yes
associated: yes
preamble: long
WMM/WME: yes
MFP: yes
TDLS peer: no
DTIM period: 1
beacon interval:100
short slot time:yes
connected time: 197 seconds
associated at [boottime]: 9.328s
associated at: 1780421266454 ms
current time: 1780421463579 ms
give me the output of
sudo iw dev wlp1s0 scan | grep -iE 'BSS|SSID|HT capab|VHT capab|HE capab|HT oper|VHT oper|HE oper|width|channel'
[sudo] password for habanero:
BSS fa:d0:0e:3d:d2:72(on wlp1s0) -- associated
SSID: Konawifi
DS Parameter set: channel 157
Channels [36 - 48] @ 30 dBm
Channels [52 - 64] @ 24 dBm
Channels [100 - 144] @ 24 dBm
Channels [149 - 165] @ 30 dBm
BSS Load:
* channel utilisation: 84/255
Nonoperating Channel Max Measurement Duration: 0
HT capabilities:
HT operation:
* primary channel: 157
* secondary channel offset: above
* STA channel width: any
* OBSS non-GF present: 1
* Extended Channel Switching
* BSS Transition
* SSID List
VHT capabilities:
VHT Capabilities (0x0f8b69b2):
Supported Channel Width: neither 160 nor 80+80
VHT operation:
* channel width: 1 (80 MHz)
HE capabilities:
BSS 4a:4b:d4:6a:2f:4e(on wlp1s0)
SSID: Kraken1
Channels [1 - 11] @ 30 dBm
BSS Load:
* channel utilisation: 81/255
AP Channel Report:
* channel(s): 157
AP Channel Report:
* channel(s): 1
HT capabilities:
HT operation:
* secondary channel offset: no secondary
* STA channel width: 20 MHz
* OBSS non-GF present: 0
Overlapping BSS scan params:
* channel width trigger scan interval: 300 s
* scan passive total per channel: 200 TUs
* scan active total per channel: 20 TUs
* BSS width channel transition delay factor: 5
* OBSS Scan Activity Threshold: 0.25 %
* BSS Transition
* SSID List
HE capabilities:
BSS f2:97:ba:32:e1:38(on wlp1s0)
DS Parameter set: channel 6
HT capabilities:
HT operation:
* primary channel: 6
BSS d8:97:ba:32:e1:38(on wlp1s0)
SSID: RSM1
HT capabilities:
HT operation:
* SSID List
BSS ba:5e:71:59:4d:9d(on wlp1s0)
SSID: orbit service
BSS Load:
* channel utilisation: 112/255
AP Channel Report:
* channel(s): 157
AP Channel Report:
* channel(s): 6
HT capabilities:
HT operation:
* BSS Transition
* SSID List
HE capabilities:
BSS f8:3e:b0:4b:5e:82(on wlp1s0)
SSID: TMOBILE-5E80
BSS Load:
* channel utilisation: 54/255
HT capabilities:
HT operation:
* BSS Transition
* SSID List
* UTF-8 SSID
HE capabilities:
Partial Bandwidth Extended Range
BSS 38:a0:67:09:0a:80(on wlp1s0)
SSID: TMOBILE-0A77
HT capabilities:
HT operation:
* BSS Transition
* SSID List
VHT capabilities:
VHT Capabilities (0x338b7992):
VHT operation:
* channel width: 0 (20 or 40 MHz)
HE capabilities:
Full Bandwidth UL MU-MIMO
BSS 0c:ef:15:f6:65:ef(on wlp1s0)
SSID: TP-Link_65F0
DS Parameter set: channel 9
HT capabilities:
HT operation:
* primary channel: 9
* BSS Transition
* SSID List
VHT capabilities:
VHT Capabilities (0x33812992):
VHT operation:
HE capabilities:
RX Control Frame to MultiBSS
BSS c6:4f:d5:5d:f5:09(on wlp1s0)
SSID: FrogPrincess
DS Parameter set: channel 11
BSS Load:
* channel utilisation: 100/255
AP Channel Report:
* channel(s): 44
AP Channel Report:
* channel(s): 11
AP Channel Report:
* channel(s): 197
HT capabilities:
HT operation:
* primary channel: 11
* BSS Transition
* SSID List
HE capabilities:
BSS f8:3e:b0:4b:5e:83(on wlp1s0)
SSID: TMOBILE-5E80
DS Parameter set: channel 40
Channels [36 - 48] @ 23 dBm
BSS Load:
* channel utilisation: 19/255
HT capabilities:
HT operation:
* primary channel: 40
* secondary channel offset: below
* BSS Transition
* SSID List
* UTF-8 SSID
VHT capabilities:
VHT Capabilities (0x338b79b1):
VHT operation:
HE capabilities:
BSS ea:97:ba:32:e1:40(on wlp1s0)
SSID: xfinitywifi
DS Parameter set: channel 153
Channels [36 - 36] @ 30 dBm
Channels [40 - 40] @ 30 dBm
Channels [44 - 44] @ 30 dBm
Channels [48 - 48] @ 30 dBm
Channels [149 - 149] @ 30 dBm
Channels [153 - 153] @ 30 dBm
Channels [157 - 157] @ 30 dBm
Channels [161 - 161] @ 30 dBm
Channels [165 - 165] @ 30 dBm
HT capabilities:
HT operation:
* primary channel: 153
* SSID List
VHT capabilities:
VHT Capabilities (0x33800192):
VHT operation:
BSS d8:97:ba:32:e1:40(on wlp1s0)
SSID: RSM1
HT capabilities:
HT operation:
* SSID List
VHT capabilities:
VHT Capabilities (0x338001b2):
VHT operation:
BSS fa:d0:0e:3d:d2:77(on wlp1s0)
BSS Load:
HT capabilities:
HT operation:
* BSS Transition
* SSID List
VHT capabilities:
VHT operation:
HE capabilities:
BSS dc:eb:69:a3:59:db(on wlp1s0)
SSID: xfinitywifi
HT capabilities:
HT operation:
VHT capabilities:
VHT Capabilities (0x3fcf78b2):
VHT operation:
* BSS Transition
* SSID List
BSS dc:eb:69:a3:59:df(on wlp1s0)
HT capabilities:
HT operation:
VHT capabilities:
VHT operation:
* SSID List
BSS ba:98:13:0a:af:5c(on wlp1s0)
HT capabilities:
HT operation:
VHT capabilities:
VHT operation:
* SSID List
BSS 7e:27:bc:18:da:39(on wlp1s0)
Channels [36 - 36] @ 23 dBm
Channels [40 - 40] @ 23 dBm
Channels [44 - 44] @ 23 dBm
Channels [48 - 48] @ 23 dBm
Channels [52 - 52] @ 24 dBm
Channels [56 - 56] @ 24 dBm
Channels [60 - 60] @ 24 dBm
Channels [64 - 64] @ 24 dBm
Channels [100 - 100] @ 24 dBm
Channels [104 - 104] @ 24 dBm
Channels [108 - 108] @ 24 dBm
Channels [112 - 112] @ 24 dBm
Channels [116 - 116] @ 24 dBm
Channels [120 - 120] @ 24 dBm
Channels [124 - 124] @ 24 dBm
Channels [128 - 128] @ 24 dBm
Channels [132 - 132] @ 24 dBm
Channels [136 - 136] @ 24 dBm
Channels [140 - 140] @ 24 dBm
Channels [144 - 144] @ 24 dBm
HT capabilities:
HT operation:
BSS dc:eb:69:a3:59:dc(on wlp1s0)
HT capabilities:
HT operation:
VHT capabilities:
VHT operation:
* BSS Transition
* SSID List
BSS dc:eb:69:a3:59:d9(on wlp1s0)
SSID: Mspamelia
HT capabilities:
HT operation:
VHT capabilities:
VHT operation:
* BSS Transition
* SSID List
BSS ba:5e:71:60:4d:98(on wlp1s0)
SSID: xfinitywifi
BSS Load:
* channel utilisation: 68/255
HT capabilities:
HT operation:
* BSS Transition
* SSID List
VHT capabilities:
VHT Capabilities (0x0f8b69b5):
Supported Channel Width: 160 MHz
VHT operation:
HE capabilities:
BSS ba:5e:71:60:4d:9a(on wlp1s0)
SSID: Xfinity Mobile
BSS Load:
HT capabilities:
HT operation:
* BSS Transition
* SSID List
HESSID: 11:22:33:44:55:66
VHT capabilities:
VHT operation:
HE capabilities:
BSS ba:5e:71:60:4d:9b(on wlp1s0)
BSS Load:
* channel utilisation: 74/255
HT capabilities:
HT operation:
* BSS Transition
* SSID List
VHT capabilities:
VHT operation:
HE capabilities:
BSS ba:5e:71:60:4d:9e(on wlp1s0)
SSID: orbit service
BSS Load:
AP Channel Report:
* channel(s): 157
HT capabilities:
HT operation:
* BSS Transition
* SSID List
VHT capabilities:
VHT operation:
HE capabilities:
BSS 38:3f:b3:3b:43:d9(on wlp1s0)
SSID: Spring2020
HT capabilities:
HT operation:
* BSS Transition
* SSID List
VHT capabilities:
VHT operation:
BSS 38:3f:b3:3b:43:dd(on wlp1s0)
BSS Load:
* channel utilisation: 18/255
HT capabilities:
HT operation:
* BSS Transition
* SSID List
VHT capabilities:
VHT operation:
BSS 1e:9d:72:32:1f:32(on wlp1s0)
SSID: CougLife
BSS Load:
* channel utilisation: 148/255
AP Channel Report:
* channel(s): 157
AP Channel Report:
* channel(s): 1
AP Channel Report:
* channel(s): 69
HT capabilities:
HT operation:
* BSS Transition
* SSID List
VHT capabilities:
VHT Capabilities (0x0f8b69b6):
VHT operation:
HE capabilities:
BSS 1e:9d:72:32:1f:34(on wlp1s0)
SSID: xfinitywifi
BSS Load:
* channel utilisation: 88/255
AP Channel Report:
* channel(s): 69
HT capabilities:
HT operation:
* BSS Transition
* SSID List
VHT capabilities:
VHT operation:
HE capabilities:
BSS dc:eb:69:a3:59:de(on wlp1s0)
HT capabilities:
HT operation:
VHT capabilities:
VHT operation:
* BSS Transition
* SSID List
BSS 4a:4b:d4:71:2f:49(on wlp1s0)
SSID: xfinitywifi
BSS Load:
HT capabilities:
HT operation:
* BSS Transition
* SSID List
VHT capabilities:
VHT operation:
HE capabilities:
BSS 4a:4b:d4:71:2f:4d(on wlp1s0)
BSS Load:
HT capabilities:
HT operation:
* BSS Transition
* SSID List
VHT capabilities:
VHT operation:
HE capabilities:
BSS 4a:4b:d4:71:2f:4f(on wlp1s0)
SSID: Kraken1
BSS Load:
AP Channel Report:
* channel(s): 157
HT capabilities:
HT operation:
* BSS Transition
* SSID List
VHT capabilities:
VHT operation:
HE capabilities:
BSS fa:d0:0e:3d:d2:74(on wlp1s0)
SSID: xfinitywifi
BSS Load:
HT capabilities:
HT operation:
* BSS Transition
* SSID List
VHT capabilities:
VHT operation:
HE capabilities:
BSS fa:d0:0e:3d:d2:76(on wlp1s0)
BSS Load:
HT capabilities:
HT operation:
* BSS Transition
* SSID List
VHT capabilities:
VHT operation:
HE capabilities:
BSS aa:98:13:0a:af:5c(on wlp1s0)
SSID: xfinitywifi
HT capabilities:
HT operation:
VHT capabilities:
VHT operation:
* BSS Transition
* SSID List
BSS c6:4f:d5:12:a8:16(on wlp1s0)
SSID: MyWifiSoCute
BSS Load:
* channel utilisation: 78/255
AP Channel Report:
* channel(s): 69
HT capabilities:
HT operation:
* BSS Transition
* SSID List
VHT capabilities:
VHT operation:
HE capabilities:
BSS 0c:ef:15:f6:65:ee(on wlp1s0)
SSID: TP-Link_65F0
DS Parameter set: channel 161
HT capabilities:
HT operation:
* primary channel: 161
* BSS Transition
* SSID List
VHT capabilities:
VHT Capabilities (0x338139b2):
VHT operation:
HE capabilities:
BSS 38:3f:b3:3b:43:df(on wlp1s0)
HT capabilities:
HT operation:
VHT capabilities:
VHT operation:
* SSID List
BSS 4a:bd:ce:16:7b:92(on wlp1s0)
SSID: Hopplers_Modem
BSS Load:
* channel utilisation: 53/255
AP Channel Report:
* channel(s): 157
HT capabilities:
HT operation:
* BSS Transition
* SSID List
VHT capabilities:
VHT operation:
HE capabilities:
BSS 4a:bd:ce:16:7b:94(on wlp1s0)
SSID: xfinitywifi
BSS Load:
HT capabilities:
HT operation:
* BSS Transition
* SSID List
VHT capabilities:
VHT operation:
HE capabilities:
BSS 38:3f:b3:3b:43:dc(on wlp1s0)
HT capabilities:
HT operation:
VHT capabilities:
VHT operation:
* BSS Transition
* SSID List
BSS ba:5e:71:34:1e:30(on wlp1s0)
BSS Load:
* channel utilisation: 66/255
HT capabilities:
HT operation:
* BSS Transition
* SSID List
VHT capabilities:
VHT operation:
HE capabilities:
BSS ba:5e:71:34:1e:33(on wlp1s0)
SSID: His & Her
BSS Load:
AP Channel Report:
* channel(s): 157
HT capabilities:
HT operation:
* BSS Transition
* SSID List
VHT capabilities:
VHT operation:
HE capabilities:
BSS 1e:9d:72:32:1f:36(on wlp1s0)
BSS Load:
* channel utilisation: 83/255
AP Channel Report:
* channel(s): 69
HT capabilities:
HT operation:
* BSS Transition
* SSID List
VHT capabilities:
VHT operation:
HE capabilities:
BSS 4a:4b:d4:71:2f:4b(on wlp1s0)
BSS Load:
* channel utilisation: 99/255
HT capabilities:
HT operation:
* BSS Transition
* SSID List
VHT capabilities:
VHT operation:
HE capabilities:
BSS c6:4f:d5:12:a8:10(on wlp1s0)
SSID: xfinitywifi
BSS Load:
AP Channel Report:
* channel(s): 69
HT capabilities:
HT operation:
* BSS Transition
* SSID List
VHT capabilities:
VHT operation:
HE capabilities:
BSS c6:4f:d5:12:a8:13(on wlp1s0)
BSS Load:
HT capabilities:
HT operation:
* BSS Transition
* SSID List
VHT capabilities:
VHT operation:
HE capabilities:
BSS c6:4f:d5:12:a8:14(on wlp1s0)
BSS Load:
HT capabilities:
HT operation:
* BSS Transition
* SSID List
VHT capabilities:
VHT operation:
HE capabilities:
BSS 38:3f:b3:3b:43:de(on wlp1s0)
HT capabilities:
HT operation:
VHT capabilities:
VHT operation:
* BSS Transition
* SSID List
BSS 38:3f:b3:3b:43:db(on wlp1s0)
SSID: xfinitywifi
HT capabilities:
HT operation:
* BSS Transition
* SSID List
VHT capabilities:
VHT operation:
BSS 84:17:ef:17:16:e5(on wlp1s0)
SSID: xfinitywifi
HT capabilities:
HT operation:
VHT capabilities:
VHT operation:
* SSID List
BSS 84:17:ef:17:16:e9(on wlp1s0)
HT capabilities:
HT operation:
VHT capabilities:
VHT operation:
* SSID List
BSS ae:98:13:0a:af:5c(on wlp1s0)
HT capabilities:
HT operation:
VHT capabilities:
VHT operation:
* BSS Transition
* SSID List
BSS a4:98:13:0a:af:5c(on wlp1s0)
SSID: JezebeII
HT capabilities:
HT operation:
VHT capabilities:
VHT operation:
* BSS Transition
* SSID List
BSS b6:98:13:0a:af:5c(on wlp1s0)
HT capabilities:
HT operation:
VHT capabilities:
VHT operation:
* BSS Transition
* SSID List
BSS 84:17:ef:17:16:e3(on wlp1s0)
SSID: Orion
HT capabilities:
HT operation:
VHT capabilities:
VHT operation:
* BSS Transition
* SSID List
BSS 38:3f:b3:3b:43:d1(on wlp1s0)
SSID: Spring2020
* channel width trigger scan interval: 200 s
HT capabilities:
HT operation:
* BSS Transition
* SSID List
BSS 1e:9d:72:32:1f:37(on wlp1s0)
BSS Load:
HT capabilities:
HT operation:
* BSS Transition
* SSID List
VHT capabilities:
VHT operation:
HE capabilities:
BSS 84:17:ef:17:16:e8(on wlp1s0)
HT capabilities:
HT operation:
VHT capabilities:
VHT operation:
* BSS Transition
* SSID List
BSS 4a:bd:ce:0f:7b:91(on wlp1s0)
BSS Load:
* channel utilisation: 31/255
AP Channel Report:
* channel(s): 157
AP Channel Report:
* channel(s): 1
HT capabilities:
HT operation:
* BSS Transition
* SSID List
HE capabilities:
BSS fa:d0:0e:36:d2:71(on wlp1s0)
SSID: Konawifi
BSS Load:
* channel utilisation: 34/255
HT capabilities:
HT operation:
* BSS Transition
* SSID List
HE capabilities:
BSS fa:d0:0e:36:d2:72(on wlp1s0)
BSS Load:
HT capabilities:
HT operation:
* BSS Transition
* SSID List
HE capabilities:
BSS fa:d0:0e:36:d2:76(on wlp1s0)
BSS Load:
HT capabilities:
HT operation:
* BSS Transition
* SSID List
HE capabilities:
BSS d4:b9:2f:0f:ee:3d(on wlp1s0)
SSID: noheliiberenicee
HT capabilities:
HT operation:
* BSS Transition
* SSID List
BSS d4:b9:2f:0f:ee:42(on wlp1s0)
HT capabilities:
HT operation:
* BSS Transition
* SSID List
BSS 64:67:72:10:1a:2f(on wlp1s0)
SSID: TMOBILE-1A2D
DS Parameter set: channel 2
BSS Load:
HT capabilities:
HT operation:
* primary channel: 2
* BSS Transition
* SSID List
* UTF-8 SSID
HE capabilities:
BSS 10:2c:b1:0b:57:de(on wlp1s0)
Channels [1 - 11] @ 20 dBm
AP Channel Report:
* channel(s): 1 2 3 4 5 6 7
AP Channel Report:
* channel(s): 5 6 7 8 9 10 11
HT capabilities:
HT operation:
BSS Load:
* channel utilisation: 5/255
BSS 18:60:41:bc:47:67(on wlp1s0)
SSID: TreeHuggerXO
DS Parameter set: channel 3
AP Channel Report:
* channel(s): 1 2 3 4 5 6 7 8 9 10 11
BSS Load:
* channel utilisation: 48/255
HT capabilities:
HT operation:
* primary channel: 3
* BSS Transition
HE capabilities:
Partial Bandwidth UL MU-MIMO
BSS 1a:60:41:fc:47:67(on wlp1s0)
AP Channel Report:
BSS Load:
HT capabilities:
HT operation:
* BSS Transition
HE capabilities:
BSS 84:17:ef:17:16:e6(on wlp1s0)
HT capabilities:
HT operation:
VHT capabilities:
VHT operation:
* BSS Transition
* SSID List
BSS f8:3e:b0:01:df:4e(on wlp1s0)
SSID: Sweetbox
DS Parameter set: channel 5
BSS Load:
* channel utilisation: 23/255
HT capabilities:
HT operation:
* primary channel: 5
* BSS Transition
* SSID List
* UTF-8 SSID
HE capabilities:
BSS 84:17:ef:17:16:de(on wlp1s0)
HT capabilities:
HT operation:
* BSS Transition
* SSID List
BSS ba:5e:71:59:4d:9a(on wlp1s0)
BSS Load:
HT capabilities:
HT operation:
* BSS Transition
* SSID List
HE capabilities:
BSS fa:d2:ac:ae:4d:84(on wlp1s0)
BSS Load:
* channel utilisation: 75/255
HT capabilities:
HT operation:
* primary channel: 44
* BSS Transition
* SSID List
VHT capabilities:
VHT operation:
HE capabilities:
BSS fa:d2:ac:ae:4d:86(on wlp1s0)
SSID: Babyface
BSS Load:
AP Channel Report:
* channel(s): 44
HT capabilities:
HT operation:
* BSS Transition
* SSID List
VHT capabilities:
VHT operation:
HE capabilities:
BSS c6:4f:d5:64:f5:08(on wlp1s0)
BSS Load:
* channel utilisation: 115/255
HT capabilities:
HT operation:
* BSS Transition
* SSID List
VHT capabilities:
VHT operation:
HE capabilities:
BSS c6:4f:d5:64:f5:0a(on wlp1s0)
SSID: FrogPrincess
BSS Load:
AP Channel Report:
* channel(s): 44
AP Channel Report:
* channel(s): 11
AP Channel Report:
* channel(s): 197
HT capabilities:
HT operation:
* BSS Transition
* SSID List
VHT capabilities:
VHT operation:
HE capabilities:
BSS c6:4f:d5:64:f5:0c(on wlp1s0)
SSID: xfinitywifi
BSS Load:
AP Channel Report:
* channel(s): 197
HT capabilities:
HT operation:
* BSS Transition
* SSID List
VHT capabilities:
VHT operation:
HE capabilities:
BSS c6:4f:d5:64:f5:0f(on wlp1s0)
BSS Load:
HT capabilities:
HT operation:
* BSS Transition
* SSID List
VHT capabilities:
VHT operation:
HE capabilities:
BSS de:97:ba:32:e1:40(on wlp1s0)
HT capabilities:
HT operation:
* SSID List
VHT capabilities:
VHT operation:
BSS 28:80:88:ab:b7:94(on wlp1s0)
SSID: NETGEAR78-5G
BSS Load:
* channel utilisation: 82/255
HT capabilities:
HT operation:
  • BSS Transition
    * SSID List
    * UTF-8 SSID
    HE capabilities:
    HT capabilities:
    HT operation:
    * BSS Transition
    * SSID List
    BSS Load:
    HT capabilities:
    HT operation:
    * BSS Transition
    * SSID List
    HE capabilities:
    BSS Load:
    HT capabilities:
    HT operation:
    * BSS Transition
    * SSID List
    VHT capabilities:
    VHT operation:
    HE capabilities:
    SSID: Babyface
    BSS Load:
    AP Channel Report:
    * channel(s): 44
    HT capabilities:
    HT operation:
    * BSS Transition
    * SSID List
    VHT capabilities:
    VHT operation:
    HE capabilities:
    BSS Load:
    HT capabilities:
    HT operation:
    * BSS Transition
    * SSID List
    VHT capabilities:
    VHT operation:
    HE capabilities:
    SSID: FrogPrincess
    BSS Load:
    AP Channel Report:
    * channel(s): 44
    AP Channel Report:
    * channel(s): 11
    AP Channel Report:
    * channel(s): 197
    HT capabilities:
    HT operation:
    * BSS Transition
    * SSID List
    VHT capabilities:
    VHT operation:
    HE capabilities:
    SSID: xfinitywifi
    BSS Load:
    AP Channel Report:
    * channel(s): 197
    HT capabilities:
    HT operation:
    * BSS Transition
    * SSID List
    VHT capabilities:
    VHT operation:
    HE capabilities:
    BSS Load:
    HT capabilities:
    HT operation:
    * BSS Transition
    * SSID List
    VHT capabilities:
    VHT operation:
    HE capabilities:
    HT capabilities:
    HT operation:
    * SSID List
    VHT capabilities:
    VHT operation:
    SSID: NETGEAR78-5G
    BSS Load:
    HT capabilities:
    HT operation:
    * BSS Transition
    VHT capabilities:
    VHT Capabilities (0x0f8369b2):
    VHT operation:
    BSS e2:97:ba:32:e1:40(on wlp1s0)
    HT capabilities:
    HT operation:
    * SSID List
    VHT capabilities:
    VHT operation:
    BSS 2e:ef:15:f6:65:ee(on wlp1s0)
    HT capabilities:
    HT operation:
    * SSID List
    VHT capabilities:
    VHT operation:
    HE capabilities:
    BSS 5e:22:da:03:df:e7(on wlp1s0)
    AP Channel Report:
    * channel(s): 6
    AP Channel Report:
    * channel(s): 69
    BSS Load:
    HT capabilities:
    HT operation:
    * SSID List
    VHT capabilities:
    VHT operation:
    HE capabilities:
Ok do that now and show me
sudo iw dev wlp1s0 set bitrates
sudo iw dev wlp1s0 set power_save off
nmcli con down Konawifi && nmcli con up Konawifi
iw dev wlp1s0 link
SSID: Konawifi
freq: 5785.0
RX: 134203 bytes (356 packets)
TX: 86342 bytes (194 packets)
signal: -37 dBm
dtim period: 1
beacon int: 100
that now
sudo journalctl -b -k | grep -i rtw89 | tail -40
journalctl -b -u NetworkManager | grep -iE 'wlp1s0|assoc|HT|VHT|HE|rate|coex'
un 02 12:18:08 habanero-IdeaPad-5-15ABA7 kernel: rtw89_8852be_git 0000:01:00.0: loaded firmware rtw89/rtw8852b_fw-2.bin
Jun 02 12:18:08 habanero-IdeaPad-5-15ABA7 kernel: rtw89_8852be_git 0000:01:00.0: enabling device (0000 -> 0003)
Jun 02 12:18:08 habanero-IdeaPad-5-15ABA7 kernel: rtw89_8852be_git 0000:01:00.0: git commit
Jun 02 12:18:08 habanero-IdeaPad-5-15ABA7 kernel: rtw89_8852be_git 0000:01:00.0: MAC has already powered on
Jun 02 12:18:08 habanero-IdeaPad-5-15ABA7 kernel: rtw89_8852be_git 0000:01:00.0: Firmware version 0.29.29.15 (6fb3ec41), cmd version 0, type 5
Jun 02 12:18:08 habanero-IdeaPad-5-15ABA7 kernel: rtw89_8852be_git 0000:01:00.0: Firmware version 0.29.29.15 (6fb3ec41), cmd version 0, type 3
Jun 02 12:18:09 habanero-IdeaPad-5-15ABA7 kernel: rtw89_8852be_git 0000:01:00.0: Firmware element BB version: 00 28 00 00
Jun 02 12:18:09 habanero-IdeaPad-5-15ABA7 kernel: rtw89_8852be_git 0000:01:00.0: Firmware element radio A version: 00 32 00 00
Jun 02 12:18:09 habanero-IdeaPad-5-15ABA7 kernel: rtw89_8852be_git 0000:01:00.0: Firmware element NCTL version: 00 0a 00 00
Jun 02 12:18:09 habanero-IdeaPad-5-15ABA7 kernel: rtw89_8852be_git 0000:01:00.0: Firmware element TXPWR version: 00 43 00 00
Jun 02 12:18:09 habanero-IdeaPad-5-15ABA7 kernel: rtw89_8852be_git 0000:01:00.0: Firmware element PWR_TRK version: 00 32 00 00
Jun 02 12:18:09 habanero-IdeaPad-5-15ABA7 kernel: rtw89_8852be_git 0000:01:00.0: Firmware element REGD version: 00 49 00 33
Jun 02 12:18:09 habanero-IdeaPad-5-15ABA7 kernel: rtw89_8852be_git 0000:01:00.0: chip info CID: 0, CV: 1, AID: 0, ACV: 1, RFE: 1
Jun 02 12:18:09 habanero-IdeaPad-5-15ABA7 kernel: rtw89_8852be_git 0000:01:00.0: rfkill hardware state changed to enable
Jun 02 12:18:09 habanero-IdeaPad-5-15ABA7 kernel: rtw89_8852be_git 0000:01:00.0 wlp1s0: renamed from wlan0
Jun 02 12:18:09 habanero-IdeaPad-5-15ABA7 generate[866]: Permissions for /lib/netplan/00-network-manager-all.yaml are too open. Netplan configuration should NOT be accessible by others.
Jun 02 12:18:09 habanero-IdeaPad-5-15ABA7 NetworkManager[843]: [1780427889.2533] device (lo): state change: ip-config -> ip-check (reason 'none', sys-iface-state: 'external')
Jun 02 12:18:09 habanero-IdeaPad-5-15ABA7 NetworkManager[843]: [1780427889.2545] device (lo): state change: ip-check -> secondaries (reason 'none', sys-iface-state: 'external')
Jun 02 12:18:09 habanero-IdeaPad-5-15ABA7 NetworkManager[843]: [1780427889.2994] audit: op="networking-control" arg="connectivity-check-enabled:off" pid=1009 uid=0 result="success"
Jun 02 12:18:09 habanero-IdeaPad-5-15ABA7 NetworkManager[843]: [1780427889.3397] device (wlan0): interface index 2 renamed iface from 'wlan0' to 'wlp1s0'
Jun 02 12:18:09 habanero-IdeaPad-5-15ABA7 NetworkManager[843]: [1780427889.3434] device (wlp1s0): state change: unmanaged -> unavailable (reason 'managed', sys-iface-state: 'external')
Jun 02 12:18:09 habanero-IdeaPad-5-15ABA7 NetworkManager[843]: [1780427889.4732] device (wlp1s0): supplicant interface state: internal-starting -> disconnected
Jun 02 12:18:09 habanero-IdeaPad-5-15ABA7 NetworkManager[843]: [1780427889.4733] Wi-Fi P2P device controlled by interface wlp1s0 created
Jun 02 12:18:09 habanero-IdeaPad-5-15ABA7 NetworkManager[843]: [1780427889.4734] manager: (p2p-dev-wlp1s0): new 802.11 Wi-Fi P2P device (/org/freedesktop/NetworkManager/Devices/3)
Jun 02 12:18:09 habanero-IdeaPad-5-15ABA7 NetworkManager[843]: [1780427889.4735] device (p2p-dev-wlp1s0): state change: unmanaged -> unavailable (reason 'managed', sys-iface-state: 'external')
Jun 02 12:18:09 habanero-IdeaPad-5-15ABA7 NetworkManager[843]: [1780427889.4737] device (wlp1s0): state change: unavailable -> disconnected (reason 'supplicant-available', sys-iface-state: 'managed')
Jun 02 12:18:09 habanero-IdeaPad-5-15ABA7 NetworkManager[843]: [1780427889.4739] device (p2p-dev-wlp1s0): state change: unavailable -> disconnected (reason 'none', sys-iface-state: 'managed')
Jun 02 12:18:13 habanero-IdeaPad-5-15ABA7 NetworkManager[843]: [1780427893.3081] device (wlp1s0): Activation: starting connection 'Konawifi' (0f8c0ce0-1a5c-4b05-9522-ab619db8b3dc)
Jun 02 12:18:13 habanero-IdeaPad-5-15ABA7 NetworkManager[843]: [1780427893.3081] device (wlp1s0): state change: disconnected -> prepare (reason 'none', sys-iface-state: 'managed')
Jun 02 12:18:13 habanero-IdeaPad-5-15ABA7 NetworkManager[843]: [1780427893.3083] device (wlp1s0): state change: prepare -> config (reason 'none', sys-iface-state: 'managed')
Jun 02 12:18:13 habanero-IdeaPad-5-15ABA7 NetworkManager[843]: [1780427893.3085] device (wlp1s0): Activation: (wifi) access point 'Konawifi' has security, but secrets are required.
Jun 02 12:18:13 habanero-IdeaPad-5-15ABA7 NetworkManager[843]: [1780427893.3085] device (wlp1s0): state change: config -> need-auth (reason 'none', sys-iface-state: 'managed')
Jun 02 12:18:13 habanero-IdeaPad-5-15ABA7 NetworkManager[843]: [1780427893.3086] sup-iface[c8b3e7ab82a48c47,0,wlp1s0]: wps: type pbc start...
Jun 02 12:18:13 habanero-IdeaPad-5-15ABA7 NetworkManager[843]: [1780427893.3090] device (wlp1s0): state change: need-auth -> prepare (reason 'none', sys-iface-state: 'managed')
Jun 02 12:18:13 habanero-IdeaPad-5-15ABA7 NetworkManager[843]: [1780427893.3091] device (wlp1s0): state change: prepare -> config (reason 'none', sys-iface-state: 'managed')
Jun 02 12:18:13 habanero-IdeaPad-5-15ABA7 NetworkManager[843]: [1780427893.3092] device (wlp1s0): Activation: (wifi) connection 'Konawifi' has security, and secrets exist. No new secrets needed.
Jun 02 12:18:13 habanero-IdeaPad-5-15ABA7 NetworkManager[843]: [1780427893.3100] device (wlp1s0): supplicant interface state: disconnected -> scanning
Jun 02 12:18:13 habanero-IdeaPad-5-15ABA7 NetworkManager[843]: [1780427893.3100] device (p2p-dev-wlp1s0): supplicant management interface state: disconnected -> scanning
Jun 02 12:18:13 habanero-IdeaPad-5-15ABA7 NetworkManager[843]: [1780427893.6424] device (wlp1s0): supplicant interface state: scanning -> authenticating
Jun 02 12:18:13 habanero-IdeaPad-5-15ABA7 NetworkManager[843]: [1780427893.6425] device (p2p-dev-wlp1s0): supplicant management interface state: scanning -> authenticating
Jun 02 12:18:13 habanero-IdeaPad-5-15ABA7 NetworkManager[843]: [1780427893.6739] device (wlp1s0): supplicant interface state: authenticating -> associating
Jun 02 12:18:13 habanero-IdeaPad-5-15ABA7 NetworkManager[843]: [1780427893.6739] device (p2p-dev-wlp1s0): supplicant management interface state: authenticating -> associating
Jun 02 12:18:13 habanero-IdeaPad-5-15ABA7 NetworkManager[843]: [1780427893.9786] agent-manager: agent[d168e68b49be14a5,:1.40/org.gnome.Shell.NetworkAgent/121]: agent registered
Jun 02 12:18:14 habanero-IdeaPad-5-15ABA7 NetworkManager[843]: [1780427894.0280] device (wlp1s0): supplicant interface state: associating -> disconnected
Jun 02 12:18:14 habanero-IdeaPad-5-15ABA7 NetworkManager[843]: [1780427894.0280] device (p2p-dev-wlp1s0): supplicant management interface state: associating -> disconnected
Jun 02 12:18:14 habanero-IdeaPad-5-15ABA7 NetworkManager[843]: [1780427894.2385] device (wlp1s0): supplicant interface state: disconnected -> scanning
Jun 02 12:18:14 habanero-IdeaPad-5-15ABA7 NetworkManager[843]: [1780427894.2385] device (p2p-dev-wlp1s0): supplicant management interface state: disconnected -> scanning
Jun 02 12:18:14 habanero-IdeaPad-5-15ABA7 NetworkManager[843]: [1780427894.4969] device (wlp1s0): supplicant interface state: scanning -> authenticating
Jun 02 12:18:14 habanero-IdeaPad-5-15ABA7 NetworkManager[843]: [1780427894.4969] device (p2p-dev-wlp1s0): supplicant management interface state: scanning -> authenticating
Jun 02 12:18:14 habanero-IdeaPad-5-15ABA7 NetworkManager[843]: [1780427894.5325] device (wlp1s0): supplicant interface state: authenticating -> associating
Jun 02 12:18:14 habanero-IdeaPad-5-15ABA7 NetworkManager[843]: [1780427894.5326] device (p2p-dev-wlp1s0): supplicant management interface state: authenticating -> associating
Jun 02 12:18:14 habanero-IdeaPad-5-15ABA7 NetworkManager[843]: [1780427894.6661] device (wlp1s0): supplicant interface state: associating -> 4way_handshake
Jun 02 12:18:14 habanero-IdeaPad-5-15ABA7 NetworkManager[843]: [1780427894.6662] device (p2p-dev-wlp1s0): supplicant management interface state: associating -> 4way_handshake
Jun 02 12:18:14 habanero-IdeaPad-5-15ABA7 NetworkManager[843]: [1780427894.7157] device (wlp1s0): supplicant interface state: 4way_handshake -> completed
Jun 02 12:18:14 habanero-IdeaPad-5-15ABA7 NetworkManager[843]: [1780427894.7157] device (wlp1s0): Activation: (wifi) Stage 2 of 5 (Device Configure) successful. Connected to wireless network "Konawifi"
Jun 02 12:18:14 habanero-IdeaPad-5-15ABA7 NetworkManager[843]: [1780427894.7158] device (p2p-dev-wlp1s0): supplicant management interface state: 4way_handshake -> completed
Jun 02 12:18:14 habanero-IdeaPad-5-15ABA7 NetworkManager[843]: [1780427894.7159] device (wlp1s0): state change: config -> ip-config (reason 'none', sys-iface-state: 'managed')
Jun 02 12:18:14 habanero-IdeaPad-5-15ABA7 NetworkManager[843]: [1780427894.7161] dhcp4 (wlp1s0): activation: beginning transaction (timeout in 45 seconds)
Jun 02 12:18:14 habanero-IdeaPad-5-15ABA7 NetworkManager[843]: [1780427894.7339] dhcp4 (wlp1s0): state changed new lease, address=10.0.0.147, acd pending
Jun 02 12:18:14 habanero-IdeaPad-5-15ABA7 NetworkManager[843]: [1780427894.8574] dhcp4 (wlp1s0): state changed new lease, address=10.0.0.147
Jun 02 12:18:14 habanero-IdeaPad-5-15ABA7 NetworkManager[843]: [1780427894.8581] policy: set 'Konawifi' (wlp1s0) as default for IPv4 routing and DNS
Jun 02 12:18:14 habanero-IdeaPad-5-15ABA7 NetworkManager[843]: [1780427894.8622] device (wlp1s0): state change: ip-config -> ip-check (reason 'none', sys-iface-state: 'managed')
Jun 02 12:18:14 habanero-IdeaPad-5-15ABA7 NetworkManager[843]: [1780427894.8631] device (wlp1s0): state change: ip-check -> secondaries (reason 'none', sys-iface-state: 'managed')
Jun 02 12:18:14 habanero-IdeaPad-5-15ABA7 NetworkManager[843]: [1780427894.8632] device (wlp1s0): state change: secondaries -> activated (reason 'none', sys-iface-state: 'managed')
Jun 02 12:18:14 habanero-IdeaPad-5-15ABA7 NetworkManager[843]: [1780427894.8636] device (wlp1s0): Activation: successful, device activated.
Jun 02 12:18:14 habanero-IdeaPad-5-15ABA7 NetworkManager[843]: [1780427894.9118] device (wg0-mullvad): state change: ip-config -> ip-check (reason 'none', sys-iface-state: 'external')
Jun 02 12:18:14 habanero-IdeaPad-5-15ABA7 NetworkManager[843]: [1780427894.9130] device (wg0-mullvad): state change: ip-check -> secondaries (reason 'none', sys-iface-state: 'external')
Jun 02 12:18:20 habanero-IdeaPad-5-15ABA7 NetworkManager[843]: [1780427900.2767] agent-manager: agent[529b2f8a9642baea,:1.78/org.gnome.Shell.NetworkAgent/1000]: agent registered
Jun 02 12:18:25 habanero-IdeaPad-5-15ABA7 NetworkManager[843]: [1780427905.3640] device (wlp1s0): supplicant interface state: completed -> authenticating
Jun 02 12:18:25 habanero-IdeaPad-5-15ABA7 NetworkManager[843]: [1780427905.3640] device (p2p-dev-wlp1s0): supplicant management interface state: completed -> authenticating
Jun 02 12:18:25 habanero-IdeaPad-5-15ABA7 NetworkManager[843]: [1780427905.3749] device (wlp1s0): supplicant interface state: authenticating -> associating
Jun 02 12:18:25 habanero-IdeaPad-5-15ABA7 NetworkManager[843]: [1780427905.3749] device (p2p-dev-wlp1s0): supplicant management interface state: authenticating -> associating
Jun 02 12:18:25 habanero-IdeaPad-5-15ABA7 NetworkManager[843]: [1780427905.5077] device (wlp1s0): supplicant interface state: associating -> completed
Jun 02 12:18:25 habanero-IdeaPad-5-15ABA7 NetworkManager[843]: [1780427905.5079] device (wlp1s0): ip:dhcp4: restarting
Jun 02 12:18:25 habanero-IdeaPad-5-15ABA7 NetworkManager[843]: [1780427905.5079] dhcp4 (wlp1s0): canceled DHCP transaction
Jun 02 12:18:25 habanero-IdeaPad-5-15ABA7 NetworkManager[843]: [1780427905.5079] dhcp4 (wlp1s0): activation: beginning transaction (timeout in 45 seconds)
Jun 02 12:18:25 habanero-IdeaPad-5-15ABA7 NetworkManager[843]: [1780427905.5079] dhcp4 (wlp1s0): state changed no lease
Jun 02 12:18:25 habanero-IdeaPad-5-15ABA7 NetworkManager[843]: [1780427905.5080] dhcp4 (wlp1s0): activation: beginning transaction (timeout in 45 seconds)
Jun 02 12:18:25 habanero-IdeaPad-5-15ABA7 NetworkManager[843]: [1780427905.5081] device (p2p-dev-wlp1s0): supplicant management interface state: associating -> completed
Jun 02 12:18:25 habanero-IdeaPad-5-15ABA7 NetworkManager[843]: [1780427905.5191] dhcp4 (wlp1s0): state changed new lease, address=10.0.0.147, acd pending
Jun 02 12:18:25 habanero-IdeaPad-5-15ABA7 NetworkManager[843]: [1780427905.5193] dhcp4 (wlp1s0): state changed new lease, address=10.0.0.147
do that
modinfo rtw89_8852be | head -3
sudo modprobe -r rtw89_8852be_git rtw89_8852b_git rtw89_pci_git rtw89_core_git
sudo modprobe rtw89_8852be
iw dev wlp1s0 link
SSID: Konawifi
freq: 5785.0
RX: 116507 bytes (302 packets)
TX: 74856 bytes (141 packets)
signal: -41 dBm
dtim period: 1
beacon int: 100
It's still averaging 18mbps download
That now
ethtool -i wlp1s0
lsmod | grep rtw89
driver: rtw89_8852be
version: 7.0.11-1-liquorix-amd64
firmware-version: 0.29.29.15
expansion-rom-version:
bus-info: 0000:01:00.0
supports-statistics: yes
supports-test: no
supports-eeprom-access: no
supports-register-dump: no
supports-priv-flags: no
habanero@habanero-IdeaPad-5-15ABA7:~$ lsmod | grep rtw89
rtw89_8852be 12288 0
rtw89_8852b_git 348160 1 rtw89_8852be
rtw89_pci_git 110592 1 rtw89_8852be
rtw89_8852b_common_git 61440 1 rtw89_8852b_git
rtw89_core_git 1155072 3 rtw89_pci_git,rtw89_8852b_common_git,rtw89_8852b_git
mac80211 1597440 2 rtw89_pci_git,rtw89_core_git
cfg80211 1449984 4 wl,rtw89_8852b_common_git,rtw89_core_git,mac80211
rfkill 45056 9 rtw89_core_git,bluetooth,ideapad_laptop,cfg8021
reboot, and after give me that
sudo iw dev wlp1s0 scan | grep -iB1 -A6 'multiple bssid'
It's not responding to that command.
ok
grep -r rtw89 /etc/modprobe.d/
/etc/modprobe.d/rtw89.conf:# Configuration file for the out-of-kernel rtw89 drivers
/etc/modprobe.d/rtw89.conf:# Link: GitHub - morrownr/rtw89: Linux drivers for Realtek Wi-Fi 6/6E and Wi-Fi 7 adapters and cards · GitHub
/etc/modprobe.d/rtw89.conf:options rtw89_core_git debug_mask=0x0
/etc/modprobe.d/rtw89.conf:options rtw89_core_git disable_ps_mode=n
/etc/modprobe.d/rtw89.conf:options rtw89_pci_git disable_clkreq=n
/etc/modprobe.d/rtw89.conf:options rtw89_pci_git disable_aspm_l1=n
/etc/modprobe.d/rtw89.conf:options rtw89_pci_git disable_aspm_l1ss=n
/etc/modprobe.d/rtw89.conf:options rtw89_usb_git switch_usb_mode=y
/etc/modprobe.d/rtw89.conf:# Blacklist the in-kernel rtw89 drivers
/etc/modprobe.d/rtw89.conf:blacklist rtw89_8851bu
/etc/modprobe.d/rtw89.conf:blacklist rtw89_8851be
/etc/modprobe.d/rtw89.conf:blacklist rtw89_8852au
/etc/modprobe.d/rtw89.conf:blacklist rtw89_8852ae
/etc/modprobe.d/rtw89.conf:blacklist rtw89_8852b_common
/etc/modprobe.d/rtw89.conf:blacklist rtw89_8852bu
/etc/modprobe.d/rtw89.conf:blacklist rtw89_8852be
/etc/modprobe.d/rtw89.conf:blacklist rtw89_8852bte
/etc/modprobe.d/rtw89.conf:blacklist rtw89_8852cu
/etc/modprobe.d/rtw89.conf:blacklist rtw89_8852ce
/etc/modprobe.d/rtw89.conf:blacklist rtw89_8922au
/etc/modprobe.d/rtw89.conf:blacklist rtw89_8922ae
/etc/modprobe.d/rtw89.conf:blacklist rtw89_core
/etc/modprobe.d/rtw89.conf:blacklist rtw89_usb
/etc/modprobe.d/rtw89.conf:blacklist rtw89_pci
/etc/modprobe.d/rtw89.conf:# Blacklist Larry's rtw89 drivers
/etc/modprobe.d/rtw89.conf:blacklist rtw89core
/etc/modprobe.d/rtw89.conf:blacklist rtw89pci
that now
sudo dmesg | grep -iE 'required MCSes|disabling HT'
[ 8.823819] wlp1s0: required MCSes not supported, disabling HT
I'll be back in a few hours. Thank you again for this troubleshooting. I am learning alot.
