Small bug Z v18 Pro
Hi there, just small bug I notice on Z 18 Pro.
I am seeing this white window at the top of the screen, when starting some applications or run a app from the terminal. It disappears on it's own after about 3 seconds.
/dev/sdb1
cheers CD
It is best to post a screenshot attached in your post.
To do that, from the Reply box, select the upload tool (6th from left) and choose image file (needs to be <1MB) to attach.
I have taken your image, reduced its size (<1MB) and display it here:
Question: Does the white window change if you move mouse cursor to/from top of screen?
Hi there, thanks for your reply.
Understood about the screenshots, I was enjoying the luxury of the way Z takes screenshots and adds them to the buffer for pasting in one step.
The white window disappears on it's own after about 3 seconds. It first appears thinner then jumps to a thicker one, then disappears.
Moving the cursor or clicking on the desktop doesn't seem to affect it.
There is some very small text in the far left edge of it. I'll try and video it.
It feels like it appears at the time I first open an app.
So far, noticed it when opening Brave (not the default), Libra word, pika and software.
No difference if its the full install or the limited install.
cheers CD
Hi there
Here you go.
here's the text
cheers CD
In your Z18 Pro, Zorin Appearance Settings, Do you have Advanced Window Tiling switched =ON ?
See these 2 posts: How to turn off snap grid at top of screen? - #14 by zabadabadoo
How to turn off snap grid at top of screen? - #15 by StarTreker
I am wondering if the white area is a consequence of that setting?
No, advanced tiling is disabled.
I think it is related to an error message, because I can replicate it by attempting to add the /boot or the /etc folder to a 'Pika backup' job.
cheers CD
Hi there again - Update
The thick white stripe is definitely related to a warning message. Because in my testing of my printer the thing showed up every time I printed a doc.
Cheers CD
