software-properties-gtk
File “/usr/bin/software-properties-gtk”, line 100, in
app = SoftwarePropertiesGtk(datadir=options.data_dir, options=options, file=file)
File “/usr/lib/python3/dist-packages/softwareproperties/gtk/SoftwarePropertiesGtk.py”, line 116, in init
SoftwareProperties.init(self, options=options, datadir=datadir)
File “/usr/lib/python3/dist-packages/softwareproperties/SoftwareProperties.py”, line 117, in init
self.reload_sourceslist()
File “/usr/lib/python3/dist-packages/softwareproperties/SoftwareProperties.py”, line 612, in reload_sourceslist
self.distro.get_sources(self.sourceslist)
File “/usr/lib/python3/dist-packages/aptsources/distro.py”, line 93, in get_sources
(self.id, self.codename))
aptsources.distro.NoDistroTemplateException: Error: could not find a distribution template for Zorin/bionic
What`s problem?
Can you try:
- Zorin Menu -> System Tools -> Software Updater -> Settings to see if you can access using this way?
- Reinstall the package with Synaptic?
Nothing helps
Also reinstall, python3-software-properties. If that doesn’t fix it, do the same for software-properties-common.
Is this a new install? Did Software Updater run successfully in the past?
