Software updater issue
hello, i found that software updater has spinning wheel of death on new install it seems making individual selections not possible it will trigger persistant loading state. i could not reproduce this on zorin pro or my laptop installation.
hw microstar ms7c56
processor 3700x
nvidia graphics
os zorin 17.2 corr
type 64bit
window x11
/proc/version
6.8.0-40-generic build cy02-amd64-078
x64-gcc-12 buntu 12.3.0 22.04.3
binutils 2.38
:melting_face:
How is Your Source set up? Are You have chosen ''Main Server'' in Software & Updates? It is on the first Tab (please don't be irritated by the Language; my System is in german):
Another Thing: When You type in the Terminal sudo apt update && sudo apt upgrade what Output do you get? Any Warnings or Error Messages?
i switched from usa->main and will report back when new updates roll in. i suspect you are very much correct but i dont know why. my other installations are working with no issues on intel hw with default selections. :sweat_smile:
Test it and we will see. Did you checked it with the Terminal Command if there are any Errors?
