Hi there, since installing Zorin OS 16.3 (fresh install), 5 applications have been stuck 'Installing in my Software Center.
- Freedesktop Platform
- Gnome Application Platform version 43
- Gnome Application Platform version 44
- KDE Application Platform 5.15
- KDE Application Platform 6.4
How do I clear these? They've been sitting for hours and persist through reboots.
You might also try using terminal;
flatpak update
sudo apt update && sudo apt dist-upgrade
Those look like Flatpaks in your screenshot.
@Aravisian and @Turtle11, appreciate the quick response.
flatpak update definitely did the trick, took about 3 times but all completed.
I'll keep the other link handy as well for troubleshooting software center. Thank you both!
system
Closed
5
