Hi there!
After trying tons of articles and how-tos, I gave up on trying to set up my headset on ZorinOS 16.1 Core.
My laptop is an Asus x45C.
Intel sound card ALC270
My headset is a wired Phillips TAUH201BK/00
Does anyone also struggle with this?
The headset is working perfectly on Windows and smartphones.
When I plug it on my laptop, only the audio works. On Settings -> Sound, on Output Device, I can see the option "Headphones - Built-in Audio".
In the Input Device show "Internal Microphone - Built-in Audio" which is the laptop microphone.
It also show the option "Microphone - Built-in Audio" but the curious thing is this is not the headset microphone. When I set this device and speak near the headset microphone, it doesn't detect any sound, BUT if I poke or speak inside the headset earbud, the system detects a sound coming from the earbud. Crazy like that!
In my /etc/modprobe.d/alsa-base.conf I've tried several options but now it's like that:
Alsamixer
In this last image, you can see alsamixer shows on the top "Item Headphone Mic [Off]" and I don't know why. I don't know how to enable it too.
In AlsaMixer, when I press F4, it shows the "Capture" screen like this one bellow:
In this picture you can see that the first item is called "Headphone Mic" and it says its "Off", which means that I can set it's levels like the other items next to it.
In Qasmixer, see if checking Mic Boost and Mic Extra Boost helps.
Having looked at an unpacking video of your headphones, have you tried turning on and off the mic with the switch on one of the cables?
The 3rd item, "Headphone Mic" is still Off. The 4th and 5th items are "Headphone Mic Boost" but it doesn't change anything.
I tried Enable the Auto-mute but I didn't notice any change either. =/
I think the problem is the microphone present in the headphone wasn't detected... so no matter what I change in Alsamixer, it doesn't seen change anything
