[SOLVED] Random hard locks/freezes on CyberPowerPC desktop with Radeon RX 7700 XT – Zorin OS 18
Hi folks,
My CyberPowerPC (Ryzen + Radeon RX 7700 XT 12GB) was suffering brutal random freezes—screen locked, no input, had to hard reboot. Journalctl/dmesg showed amdgpu ring timeouts in GNOME Shell:
"ring gfx_0.0.0 timeout"
"GPU reset begin!" → then SMU stuck ("SMU: I'm not done with your previous command") and recovery fail loops.
Tried kernel hopping, but this finally killed the problem (stable for days now):
  1. Switched to Zorin OS 18 default kernel: 6.14
    (6.11 was buggy for RDNA3 reset handling—6.14 fixed a bunch.)
sudo apt update && sudo apt install --reinstall linux-generic
Select in GRUB if needed.
  1. Updated AMDGPU firmware (fixed the SMU hangs):
sudo apt install git
git clone https://git.kernel.org/pub/scm/linux/kernel/git/firmware/linux-firmware.git
sudo cp linux-firmware/amdgpu/  /lib/firmware/amdgpu/
sudo update-initramfs -u -k all
Reboot.
Kept my kernel params:
"amdgpu.gpu_recovery=1 amdgpu.runpm=0 amdgpu.sg_display=0"
Now: clean boots, no timeouts, handles gaming/browser/desktop fine. amdgpu logs are quiet.
If you're on Zorin/Ubuntu with an RX 7700 XT (or similar 7000-series) and getting these hangs, this combo is worth trying. Specs: CyberPowerPC desktop, AMD Ryzen 7 8700F, RX 7700 XT, 16GB Ram, Zorin 18 Pro, kernel 6.14.
Hope this saves someone a headache!
