The problem doesn't occur on windows.
This fixed my popping/cracking sounds.
@anon96359095 Where did you find that fix?
Is the fix the modprobe line only, or that plus the power_save=0 line
in your post in the other thread?
I am wondering what needs to be conveyed to the OP to fix his crackling issue.
I think you misread the message.
Location of the file to edit /etc/modprobe.d/alsa-base.conf
- Open terminal and write
sudo -i - Next write
gedit /etc/modprobe.d/alsa-base.conf - Add this line
options snd-hda-intel power_save=0 power_save_controller=N snoop=0 - Save and reboot
*. This fixed alot of plopping/crackling issues for me
The problem also doesn't occur on Manjaro!
