Does anyone know the name of an app from the App store to amplify sounds for my pc? I use Zorin OS Core 16. I have not been able to find anything in the app store. Thanks.
Thanks for the info, but I just now found out how to adjust sound past 100% in the settings for sound, so I don't really need an App after all. The adjustment works great for all I need. Thanks.
You might also want to install ALSA apps for better sound experience over Pulse Audio.
QAS Mixer, especially if you are using surround sound system.
