Sound is gone suddenly after game error to forced log out
Downloading some big files in the backround while running a moderately light game on Wine-10.0-rc1(staging) to kill some time. Then for some reason alt tabbing makes the game automatically sets to windowed mode. The moment i applied fullscreen my screen goes black and was logged out of desktop. i had to log in three times to get to desktop. I get back to see my download wasnt interrupted but for some reason the audio is fully gone.
i checked both sound settings and pulseaudio to find out that no sound source is detected.
Game crashed > Crashed desktop also > log back in > no sound
Have you yet tried using pavucontrol to reset your sound output?
sudo apt install pavucontrol
Launch:
pavucontrol
In the output tab, set your output to your desired speakers - test sound.
does it usually take a long time? been waiting for a while now
Can you close pavucontrol and in terminal, run:
pulseaudio -k
Then:
systemctl --user restart pulseaudio.service
Then relaunch Pavucontrol and check...
i feel as if some sort of error had happened in the back due to some programs outside my control
Maybe you are using Pipewire...
systemctl --user restart pipewire.service
sam-bridges@sambridges:~$ systemctl --user restart pipewire.service
Failed to restart pipewire.service: Process org.freedesktop.systemd1 exited with status 1
See user logs and 'systemctl --user status pipewire.service' for details.
sam-bridges@sambridges:~$ systemctl --user status pipewire.service
Failed to get properties: Process org.freedesktop.systemd1 exited with status 1
should i try restarting my device?
this seems suspicious
What is your output for
systemctl --user dbus.service
Yes, that is always worth trying...
sam-bridges@sambridges:~$ systemctl --user dbus.service
Unknown command verb dbus.service.
it doesn't seem to do anything. But fortunately i manage to solve it in a way unexpected.
I entered the Zorin BIOS and boot up the older OS kernel 6.5.0-41-generic, x86_64. now the sounds are back like usual.
Its so random. all errors i've encountered just appears to happen suddenly after updates and more updates.
but nonetheless, Thank you.
Well, glad to know it is sorted.....
