I have to manually set my audio to my headset every time I log in. This includes if my screen times out while I am using it. How do I set my audio output to not change?
sudo apt install pavucontrol
pavucontrol
What output settings are being managed by the PulseAudio controller?
I do as well, I couldn't find working fix, so I accepted it as reality. And truth is, with the Sound Output Chooser extension, I can very quickly change it from the taskbar. Maybe Aravisian will find a fix for you.
https://extensions.gnome.org/extension/906/sound-output-device-chooser/
Have you tried setting it in Alsamixer
(run it from terminal)
then save setting that works with:
sudo alsactl store
Let us know if this works for you. I am more than aware that sound problems and fixes are often trial and error.
