Audio coming from speakers (digital audio) dies out without warning at seemingly random times and I have not found a way to bring it back without restarting. Maybe it might be due to pulseaudio getting confused by the multiple sources?
- Issue does not happen in Windows installed in a separate partition. The speakers work without any problems.
- Issue also happens in Fedora 37 installed in a separate partition. In that case the instance is using pipewire-pulseaudio, and the only way to bring back audio was to turn off the audio source and turn it back on in sound settings. This does not work in Zorin.
- Connecting speakers to motherboard audio (again digital) instead of sound card does not fix the issue. Connecting 3.5mm headphones to the sound card works without any problems. This is currently my backup until I find a solution. (edit: this also has failed after a few hours)
- Pavucontrol shows audio is being outputted (the sound line moves when audio is played).
- Restarting pulseaudio with
systemctl --user restart pulseaudiodoes not change anything.
inxi
CPU: 12-Core 12th Gen Intel Core i9-12900KS (-MT MCP-) speed/min/max: 756/800/6700 MHz
Kernel: 5.15.0-57-generic x86_64 Up: 14h 12m Mem: 11169.3/31809.7 MiB (35.1%)
Storage: 21.89 TiB (67.1% used) Procs: 534 Shell: bash 5.0.17 inxi: 3.0.38
inxi -A
Audio: Device-1: Intel driver: snd_hda_intel
Device-2: NVIDIA driver: snd_hda_intel
Device-3: Creative Labs driver: snd_hda_intel
Device-4: ASUSTek USB Audio type: USB driver: hid-generic,snd-usb-audio,usbhid
Sound Server: ALSA v: k5.15.0-57-generic
sudo lshw -C multimedia
*-multimedia
description: Audio device
product: NVIDIA Corporation
vendor: NVIDIA Corporation
physical id: 0.1
bus info: pci@0000:01:00.1
version: a1
width: 32 bits
clock: 33MHz
capabilities: pm msi pciexpress bus_master cap_list
configuration: driver=snd_hda_intel latency=0
resources: irq:17 memory:87080000-87083fff
*-usb:4
product: USB Audio
vendor: Generic
physical id: 7
bus info: usb@1:7
version: 0.07
capabilities: usb-2.00 audio-control
configuration: driver=snd-usb-audio maxpower=100mA speed=480Mbit/s
*-multimedia
product: Creative Labs
vendor: Creative Labs
physical id: 0
bus info: pci@0000:04:00.0
version: 01
width: 64 bits
clock: 33MHz
capabilities: pm bus_master cap_list
configuration: driver=snd_hda_intel latency=32 maxlatency=20 mingnt=16
resources: irq:16 memory:87d04000-87d07fff memory:87d00000-87d03fff
*-multimedia
product: Intel Corporation
vendor: Intel Corporation
physical id: 1f.3
bus info: pci@0000:00:1f.3
version: 11
width: 64 bits
clock: 33MHz
capabilities: pm msi bus_master cap_list
resources: iomemory:480-47f iomemory:480-47f irq:195 memory:485e218000-485e21bfff memory:485e000000-485e0fffff
