Spotify flatpak not working
Hello,
When I try to launch Spotify I get this error:
jesuslinux@T2310Z:~$ flatpak run com.spotify.Client
jesuslinux@T2310Z:~$ libva error: /usr/lib/x86_64-linux-gnu/dri/intel-vaapi-driver/iHD_drv_video.so init failed
libva error: /usr/lib/x86_64-linux-gnu/dri/intel-vaapi-driver/i965_drv_video.so init failed
Is it a driver issue? This laptop is very old. With Intel GPU:
jesuslinux@T2310Z:~$ sudo lshw -c video
  *-display:0
       product: Mobile GM965/GL960 Integrated Graphics Controller (primary)
       vendor: Intel Corporation
       physical id: 2
       bus info: pci@0000:00:02.0
       logical name: /dev/fb0
       version: 03
       width: 64 bits
       clock: 33MHz
       capabilities: msi pm vga_controller bus_master cap_list rom fb
       configuration: depth=32 driver=i915 latency=0 resolution=1280,800
       resources: irq:16 memory:feb00000-febfffff memory:d0000000-dfffffff ioport:ec00(size=8) memory:c0000-dffff
  *-display:1 UNCLAIMED
       description: Display controller
       product: Mobile GM965/GL960 Integrated Graphics Controller (secondary)
       physical id: 2.1
       bus info: pci@0000:00:02.1
       version: 03
       width: 64 bits
       clock: 33MHz
       capabilities: pm bus_master cap_list
       configuration: latency=0
       resources: memory:fe900000-fe9fffff
Any help is appreciated.
Thanks
Flatpack apps are sandboxed and may not interact well overall with the system.
I don't use Spotify (or Flatpaks for that matter), but there are a few previous threads here on the Forum that may help of give you a steer before someone else drops by to help you. e.g.
