When I see that guy, I'll let him know.
In the meantime... Novice Aravisian will have to do.
First: Is your chip Intel? If yes
, use the below (1) and if no
skip to (2):
sudo nano /etc/default/grub
- )Change the following line:
TO:
GRUB_CMDLINE_LINUX_DEFAULT="quiet splash acpi_sleep=nonvs intel_pstate=disable"
TO:
GRUB_CMDLINE_LINUX_DEFAULT="quiet splash acpi_sleep=nonvs"
When done with (1) or (2) above - Hit ctrl+x to exit, then the y
key to say yes to save, then the enter
key to save as current configuration. The terminal will revert to normal appearance.
Enter in:
sudo update-gub
sudo reboot
and test.
Wow... thanks sir...
That I need...
Back ASAP to report this...
I try option 1 not work and now try opt 2
Still don't work with that sir... any hint... @Aravisian
Please revert your grub parameter to as it was prior to the changes. After doing so:
sudo update-gub
No need to reboot.
Novice! lol
Are you using notebook or tower pc? Year make and model?
I'm using laptop name Axioo Neon HNM year 2008
With Intel Core I7 2nd Generation
With Intel Graphics
RAM 6 GB
Hahahaha sudo update-gub....
EDIT:
Oops.
OK... Let's try this first since it is a notebook:
sudo nano /etc/systemd/logind.conf
Scroll down and find:
#HandleLidSwitch=suspend
Remove the # sign and change suspend
to ignore
HandleLidSwitch=ignore
Reboot and test. If this does not work, I still have one more trick up my sleeve...
TO:
GRUB_CMDLINE_LINUX_DEFAULT="quiet splash acpi_backlight=vendor"
sudo update-grub
reboot and test.
Hiksss sudo update-gub again
It is a new type of tutorial so that one needs to do more than just copy and paste
now... sigh... it's my fingers...
EDIT!!! I meant NO... Not NOW.../ damndiddy damnit damn damn IM CUSSIN! Try and Stop me.
/end ranting frothing edit mode.
Other common ones you will see from me are:
teh
IF
sudp
suda
I usually catch them but... I am moving so fast with the sudden activity on the forum that I am slowly converting into a miserable failure of a human being.
Thank my lucky starts that pdcromeo is sharp enough to spot and avoid them.
EDIT AGAIN^ STARS
That's it...
I quit....
Do not forget that famous
sl
(I think you need to install it first.)
sudo apt install sl
Hahahaha... if you don't mention from first place I admit I can't see it...
BTW it's work...
Just curious on
It's mean if I close my lid/laptop the screen do not sleep or standby?
That is the effect, I believe...
You can hit suspend from the app menu first, then close lid.
I try it the screen will go out but I think not sleep just turn it off the screen...
BTW it's more appropriate rather than I must hit power button twice to start a day hehehehe...
You picked the cuss post as the solution...
We are enemies, now...
Ok... It's fixed...
I must read the documentation somewhere first...
If you read the manual, you wouldn't be here.
