Is it normal to get such a message on the start?
After pressing a key, does it boot normally?
Are you on Live USB or baremetal install?
It does boot normally. Just wanted to if that is a "default" screen everyone has
Its a normal installation, not a LIVE USB
It is not the default screen, no. But if your system boots normally, I wouldn't worry too much about it.
All Operating Systems and all computers can produce some errors at point of initializing.
Ok thanks! I might install ZorinOS again since I am still testing it ![]()
