Static when using bluetooth earbuds
I have been distro hopping for a while with my new 12th gen framework laptop and found Zorin and decided to switch. I have been using Zorin for just over a month and love it! However, I have had a problem when using Bluetooth with my galaxy buds plus where the audio has a kind of static in the background when playing audio. I have already disabled the power-saving thing in the terminal, which did not solve the issue. I was looking to see if anyone had any idea why.
Would re-pairing your buds to the PC solve this?
I have tried that with no luck.
You might try disabling the powersave:
sudo -i
echo 0 > /sys/module/snd_hda_intel/parameters/power_save
That was also a thing I have tried.
