If I cannot stop using flatpak then you guys need to triple your system requirements ... this thing is sllllooooooowwwwww ![]()
Then stop using flatpaks and snaps. There's guides on the forums on howto uninstall them.
I suppose that there are a few applications that the developers will push only as flatpaks... but they are very few.
I cannot think of any reason a member should feel forced to use Flatpak.
If you list which apps you need that you can only find as Flatpak, we may be able to find you a .deb package for it.
There are so many complaints about Flatpak that I think it might even be better to disable it by default.
