Strange Audio Issues Triggered by MuseScore and OpenShot
I'm using Zorin OS 16.2.
The problem is simple. Whenever I play back any audio whilst editing in OpenShot 3.0.0, it appears to play really fast, condensing a four-minute audio clip to 28 seconds. As a result, the audio is completely unintelligible and distorted.
Likewise, any sample played by MuseScore 4.0.2 seems to be incredibly sped up to the point that a note just sounds like a short sample of white noise. In the case of MuseScore, the playback header moves really fast regardless of tempo indicated. I imagine this is because MuseScore receives feedback from the OS as to when an individual note sample has finished playing (which is really brief).
Any other audio plays back just fine even whilst the above two programs are playing audio of their own.
I've noticed that observing Settings > Sound whilst playing back audio through either program or shortly thereafter will cause a graphical glitch in that particular menu seemingly caused by "ALSA plug-in [python3.10]" appearing and disappearing very quickly under "Volume Levels." It also seems to be that the issue is resolved by simply allowing either program to run for a few minutes, after which "ALSA plug-in [mscore]" and "ALSA plug-in [python3.10]" appear (for each program respectively) under "Volume Levels" without flickering. Restarting the programs resets the issue.
If it is helpful in any way, I have an Nvidia GeForce GTX 1060 3GB plugged to my TV which I am using as a monitor via HDMI. This is also what I am using for audio output, primarily.
I recorded the issue as described above here.
I have something similar to this, while listening to my soundtracks sometimes there's a weird audio distortion/interference sound when opening something else (Firefox, a game or other software), lasts some seconds. I wonder what's wrong, maybe a high CPU usage all together.
I ditched OpenShot a while back at Zorin 10 or 11 that I used at work to edit videos from i-Pads. Wasn't a sound issue but all videos in OpenShot started appearing as a 'negative' like you see on old camera film strip. Try using KDEnlive instead - it does not mean having to install KDE (Plasma) DE. It is what i use for editing all videos I have uploaded to Vimeo.com. :wink:
I think it's a problem with the pulseaudio version Zorin is shipped with. Had similar problem when used Zorin OS. But a simple:
killall pulseaudio
did the trick when it happens.
