When I installed Zorin OS core on my hp omnibook x flip 14, I got stuck at the installation type window. When trying to erase the disk and install zorin os, I clicked teh advanced settings and clicked the option for using the LVM with the new zorin os installation. I also clicked the option jto encrypt with my own security key. After realizing that this was a bad idea, I tried to back out by clicking cancel or clicking the x in the corner. That's when I realized nothing was responding. It wasn't frozen and I could click buttons, just nothing would happen. Can someone please find out how to fix this? Thanks!
When I udnerstand You correctly, You wanted install Zorin with LVM but You already had an Encryption:
I guess that interferes. I would suggest to try it without LVM.
the thing is if i try to click anything nothing happens. thats my main problem. And thanks for the welcome.
So, You are still in the Screen now?
If you have not committed to changes and performed the installation - then you can just shut down the computer and restart - then, start the installation over from the beginning.
