Sub window drags main window with it
Is there a tweak or setting somewhere to disconnect a sub window from it's parent window behind it so that if I drag the sub window it doesn't drag the main window with it?
Thanks all
Yes, at Zorin appearance is an option to disable "attach modal dialogs". I believe it is at tab windows.
Awesome! Thank you very much. Solved.
