Sudo apt upgrade not working
running "Sudo apt update" I find that there are 18 things that could be updated. I then listed what was upgradable, these are a few of them.
libdrm-amdgpu1/jammy 2.4.112.4+2056~u22.04 amd64 [upgradable from: 2.4.107-8ubuntu1~20.04.2]
libdrm-intel1/jammy 2.4.112.4+2056~u22.04 amd64 [upgradable from: 2.4.107-8ubuntu1~20.04.2]
libdrm-nouveau2/jammy 2.4.112.4+2056~u22.04 amd64 [upgradable from: 2.4.107-8ubuntu1~20.04.2]
libdrm-radeon1/jammy 2.4.112.4+2056~u22.04 amd64 [upgradable from: 2.4.107-8ubuntu1~20.04.2]
When I go to run sudo apt upgrade I get a message that zero were upgraded. What am I doing wrong?
Hi and welcome to the forum. Those upgrades won't install because Zorin 16 is based on Ubuntu 20.04 (Focal Fossa), Jammy (Jellyfish) is the project name for Ubuntu 22.04 which is what Zorin 17 will be based on. If you had managed to install such upgrades you might break your system. So the reason nothing got upgraded was to prevent you from baulking your system.
You should also check what repositories you have added and remove any Jammy sourced Repositories.
Perfect, thank you for the help.
Thanks, but I don't see one that says Jammy. They are all Focal
These all show a Jammy source.
