Suspend and come back issues not happening on Mint
Just wanted to let you know that I ran into issues with coming back from suspend with Zorin when docked to my usb-c dock.
I currently also have an install of Mint with which I am evaluating too... and have found that Mint does not have the same issues; return from suspend works without problems.
On top, lidclose action to suspend also fails on Zorin, while on Mint no problem.
Some Zorin driver or other choice seems to be conflicting with my hardware. Not sure how to resolve... otherwise I will probably revert to using Mint.
I suggest you don't use suspend on Zorin OS. I'm on the previous version of Zorin OS, and if I let my system suspend, I can't get my computer out of it, without a force shutoff/startup.
I also disabled my lid switch in Zorin OS, as I use an external monitor, and want to leave my laptop lid closed for dust control. If suspend works on Mint, then they are doing something different over there. I've never used Mint, so I have no idea.
Can you share your hardware details?
Hardware portion of the System report (currently running Mint but probs won't make a difference anyhow).
Machine:
  Type: Convertible System: HP product: HP Spectre x360 Convertible 14-ea1xxx v: N/A
    serial: <superuser required> Chassis: type: 31 serial: <superuser required>
  Mobo: HP model: 89DA v: 40.65 serial: <superuser required> part-nu: 538F3EA#ABH
    uuid: <superuser required> UEFI: AMI v: F.34 date: 08/05/2024
Battery:
  ID-1: BAT0 charge: 60.6 Wh (100.0%) condition: 60.6/66.5 Wh (91.1%) volts: 8.7 min: 7.7
    model: HP Primary type: Li-ion serial: <filter> status: full cycles: 104
  Device-1: hidpp_battery_1 model: Logitech M720 Triathlon Multi-Device Mouse serial: <filter>
    charge: 100% (should be ignored) rechargeable: yes status: discharging
CPU:
  Info: quad core model: 11th Gen Intel Core i7-1195G7 bits: 64 type: MT MCP smt: enabled
    arch: Tiger Lake rev: 2 cache: L1: 320 KiB L2: 5 MiB L3: 12 MiB
  Speed (MHz): avg: 2043 high: 3795 min/max: 400/5000:4800 cores: 1: 3795 2: 507 3: 471 4: 3005
    5: 3754 6: 673 7: 3700 8: 440 bogomips: 46694
  Flags: avx avx2 ht lm nx pae sse sse2 sse3 sse4_1 sse4_2 ssse3 vmx
Graphics:
  Device-1: Intel TigerLake-LP GT2 [Iris Xe Graphics] vendor: Hewlett-Packard driver: i915
    v: kernel arch: Gen-12.1 ports: active: DP-1,eDP-1 empty: DP-2 bus-ID: 0000:00:02.0
    chip-ID: 8086:9a49 class-ID: 0300
  Display: x11 server: X.Org v: 21.1.11 with: Xwayland v: 23.2.6 driver: X: loaded: modesetting
    unloaded: fbdev,vesa dri: iris gpu: i915 display-ID: :0 screens: 1
  Screen-1: 0 s-res: 5760x2160 s-dpi: 96 s-size: 1524x571mm (60.00x22.48")
    s-diag: 1627mm (64.07")
  Monitor-1: DP-1 pos: primary,right model: LG (GoldStar) HDR 4K serial: <filter> res: 3840x2160
    dpi: 163 size: 600x340mm (23.62x13.39") diag: 690mm (27.2") modes: max: 3840x2160 min: 640x480
  Monitor-2: eDP-1 pos: left model: LG Display 0x0663 res: 1920x1280 hz: 60 dpi: 171
    size: 285x190mm (11.22x7.48") diag: 343mm (13.5") modes: 1920x1280
  API: EGL v: 1.5 hw: drv: intel iris platforms: device: 0 drv: iris device: 1 drv: swrast gbm:
    drv: iris surfaceless: drv: iris x11: drv: iris inactive: wayland
  API: OpenGL v: 4.6 compat-v: 4.5 vendor: intel mesa v: 24.2.8-1ubuntu1~24.04.1 glx-v: 1.4
    direct-render: yes renderer: Mesa Intel Xe Graphics (TGL GT2) device-ID: 8086:9a49
Audio:
  Device-1: Intel Tiger Lake-LP Smart Sound Audio vendor: Hewlett-Packard
    driver: sof-audio-pci-intel-tgl bus-ID: 0000:00:1f.3 chip-ID: 8086:a0c8 class-ID: 0401
  API: ALSA v: k6.8.0-59-generic status: kernel-api
  Server-1: PipeWire v: 1.0.5 status: active with: 1: pipewire-pulse status: active
    2: wireplumber status: active 3: pipewire-alsa type: plugin
Network:
  Device-1: Intel Wi-Fi 6 AX201 driver: iwlwifi v: kernel bus-ID: 0000:00:14.3 chip-ID: 8086:a0f0
    class-ID: 0280
  IF: wlo1 state: down mac: <filter>
  Device-2: ASIX AX88179 Gigabit Ethernet driver: cdc_ncm type: USB rev: 3.2 speed: 5 Gb/s
    lanes: 1 bus-ID: 2-1.1:3 chip-ID: 0b95:1790 class-ID: 0a00 serial: <filter>
  IF: enx0826ae3d8d9d state: up speed: N/A duplex: half mac: <filter>
Bluetooth:
  Device-1: Intel AX201 Bluetooth driver: btusb v: 0.8 type: USB rev: 2.0 speed: 12 Mb/s lanes: 1
    bus-ID: 3-10:5 chip-ID: 8087:0026 class-ID: e001
  Report: hciconfig ID: hci0 rfk-id: 0 state: up address: <filter> bt-v: 5.2 lmp-v: 11
    sub-v: 20f9 hci-v: 11 rev: 20f9 class-ID: 7c0000
RAID:
  Hardware-1: Intel Volume Management Device NVMe RAID Controller driver: vmd v: 0.6 port: N/A
    bus-ID: 0000:00:0e.0 chip-ID: 8086:9a0b rev: class-ID: 0104
Drives:
  Local Storage: total: 1.86 TiB used: 855.06 GiB (44.8%)
  ID-1: /dev/nvme0n1 vendor: Lexar model: SSD NM790 2TB size: 1.86 TiB speed: 63.2 Gb/s lanes: 4
    tech: SSD serial: <filter> fw-rev: 18950 temp: 34.9 C scheme: GPT
Partition:
  ID-1: / size: 963.85 GiB used: 22.47 GiB (2.3%) fs: ext4 dev: /dev/nvme0n1p7
  ID-2: /boot/efi size: 259.5 MiB used: 92.7 MiB (35.7%) fs: vfat dev: /dev/nvme0n1p1
Swap:
  ID-1: swap-1 type: file size: 2 GiB used: 512 KiB (0.0%) priority: -2 file: /swapfile
USB:
  Hub-1: 1-0:1 info: hi-speed hub with single TT ports: 1 rev: 2.0 speed: 480 Mb/s lanes: 1
    chip-ID: 1d6b:0002 class-ID: 0900
  Hub-2: 2-0:1 info: super-speed hub ports: 4 rev: 3.1 speed: 10 Gb/s lanes: 1 chip-ID: 1d6b:0003
    class-ID: 0900
  Hub-3: 2-1:2 info: Genesys Logic Hub ports: 4 rev: 3.2 speed: 5 Gb/s lanes: 1
    chip-ID: 05e3:0626 class-ID: 0900
  Device-1: 2-1.1:3 info: ASIX AX88179 Gigabit Ethernet type: communication,CDC-data
    driver: cdc_ncm interfaces: 2 rev: 3.2 speed: 5 Gb/s lanes: 1 power: 184mA chip-ID: 0b95:1790
  Device-2: 2-1.2:4 info: Genesys Logic SD Card Reader and Writer type: mass storage
    driver: usb-storage interfaces: 1 rev: 3.1 speed: 5 Gb/s lanes: 1 power: 896mA chip-ID: 05e3:0749
    class-ID: 0806 serial: <filter>
  Hub-4: 3-0:1 info: hi-speed hub with single TT ports: 12 rev: 2.0 speed: 480 Mb/s lanes: 1
  Hub-5: 3-2:2 info: Genesys Logic Hub ports: 4 rev: 2.1 speed: 480 Mb/s lanes: 1 power: 100mA
    chip-ID: 05e3:0610 class-ID: 0900
  Device-1: 3-2.4:4 info: Canon Pro9000II series type: printer driver: usblp interfaces: 1
    rev: 2.0 speed: 480 Mb/s lanes: 1 power: 2mA chip-ID: 04a9:10cf class-ID: 0701 serial: <filter>
  Device-2: 3-9:3 info: Elan Micro ELAN:ARM-M4 type: <vendor specific> driver: N/A interfaces: 1
    rev: 2.0 speed: 12 Mb/s lanes: 1 power: 100mA chip-ID: 04f3:0c4c class-ID: 0000
  Device-3: 3-10:5 info: Intel AX201 Bluetooth type: bluetooth driver: btusb interfaces: 2
    rev: 2.0 speed: 12 Mb/s lanes: 1 power: 100mA chip-ID: 8087:0026 class-ID: e001
  Hub-6: 4-0:1 info: super-speed hub ports: 4 rev: 3.1 speed: 10 Gb/s lanes: 1 chip-ID: 1d6b:0003
    class-ID: 0900
Sensors:
  System Temperatures: cpu: 58.0 C mobo: N/A
  Fan Speeds (rpm): cpu: 0 fan-2: 0
Yeah, that's fine. It's more so that we can have a better idea what we're dealing with or in case someone else with the same hardware reports the same issue. Hopefully this will get fixed soon for Zorin OS.
PS: Added some formatting to your post.
