Hello, I just started using Zorin yesterday and im loving it so far, my only issue is that when i put my PC into suspend mode or walk away and it goes into suspend mode automatically it closes all of my applications completely (Steam, brave, ect) so when i come back to my computer i have to go back and open everything i was using. so i was curious if anyone else was having this issue and how i can fix it. Thank you ![]()
The Suspend action is a different action than Hibernate.
Hibernate would preserve your open applications. Suspend shuts down all activities that draw power.
Hibernate is not enabled by default, you would need to set it up if that is what you want.
Oh ok so it is working as intended, great! thank you for your swift response i appreciate it and will use the provided resource to enable hibernation.
Don't you need a /swap partition to use Hibernate?
I understand a /swap partition is not created by the installer, only a swap file instead.
So that may complicate things.
The linked guide covers this.
