System Asking me to remove packages
I have this when trying to update and my settings have disappeared within Zorin.
acl apg cmake-data colord-data dh-elpa-helper gdal-data
gnome-bluetooth-common gnome-control-center-data gnome-control-center-faces
gnome-online-accounts hplip-data libaec0 libarmadillo10 libarpack2 libblosc1
libcapi20-3 libcdio-cdda2 libcdio-paranoia2 libcfitsio9 libcharls2
libcolord-gtk1 libcolorhug2 libdc1394-25 libdecor-0-0
libdecor-0-plugin-1-cairo libfftw3-double3 libfreexl1 libfyba0 libgdcm3.0
libgeos-c1v5 libgeos3.10.2 libgeotiff5 libgnome-bluetooth13
libgoa-backend-1.0-1 libgphoto2-port12 libgraphicsmagick++-q16-12
libgraphicsmagick-q16-3 libhdf4-0-alt libieee1284-3 libjsoncpp25 libkmlbase1
libkmldom1 libkmlengine1 libldb2 libmysqlclient21 libnfs13 libodbc2
libodbcinst2 libogdi4.1 libopencv-core4.5d libopencv-imgproc4.5d libosmesa6
libpq5 libproj22 libqhull-r8.0 librhash0 librttopo1 librygel-core-2.6-2
librygel-db-2.6-2 librygel-renderer-2.6-2 librygel-server-2.6-2
libsane-common libsane-hpaio libsdl2-2.0-0 libsmbclient libsocket++1
libspatialite7 libsuperlu5 libsz2 libtalloc2 libtbb2 libtbbmalloc2
libtevent0 liburiparser1 libwbclient0 libxerces-c3.2
mobile-broadband-provider-info mysql-common network-manager-gnome proj-bin
proj-data python3-ldb python3-macaroonbakery python3-protobuf
python3-pymacaroons python3-renderpm python3-reportlab
python3-reportlab-accel python3-rfc3339 python3-talloc python3-tz rygel
samba-libs unixodbc-common
Use 'apt autoremove' to remove them.
0 to upgrade, 0 to newly install, 0 to remove and 0 not to upgrade.
root@Zorin-lap:~#
How can i fix this without reinstalling zorin?
Do you have anything uninstalled? When something like this is shown, it is normally after uninstalling Software and these are the Rest's of it. But at least the gnome-bluetooth Package and the gnome-control-center Package are some that should be deleted.
So, that is the Reason why I ask, if You have anything uninstalled?
Run these commands...
This command scans for updates:
sudo apt-get update
This command installs updated software packages:
sudo apt-get upgrade
This command fully upgrades your OS and kernel's:
sudo apt-get dist-upgrade
And this command cleans the packages and install script.
sudo apt-get clean
Hopefully, after running these commands, your system will be functioning as expected. Please note however, this is unlikely to bring back configuration settings that you've personally set.
You will likely have to redo those. If you are having specific repository based issues, only thing that solved that for me, was removing them entirely in the software and update settings, under "other software".
Thank you. :slight_smile: that worked.
