I have just switched my iMac running Zorin 16 Core on again after a 2 day break. The only thing I have done differently is start it up with a new wireless keyboard and a wireless mouse connected via USB transmitters. They are both functioning perfectly.
I ' get an option to see what the error message is and do not know how to bring up logs and interpret them. Can anyone advise please? This message comes up every time I restart the iMac. It was previously running very smoothly.
It's actually no big deal. It just means something went wrong at some point in the time you have used the OS. You can remove that with:
sudo rm /var/crash/*
Thanks. That seems to have solved the issue.
