It worked
thank you
You see AdarshMeher, sometimes patience can help too.
But I'm curious about your backup. You wanted to backup your previous apps, which you had installed with so much effort. Did you succeed in doing so?
No, I have tried but it does not work. Everything was deleted so now I am downloading them one by one again.
Ok,
but do you still have 2 separate partition as done in the beginning when you reinstalled Zorin.
I noticed that you do like to theme your desktops and before you do wrong settings or get stuck, perhaps now or after installing the apps you want so badly, you should do a backup.
So if you do encounter any problems like the qt5-style-plugin, you don't have to wait 24h for help.
Okay, thank you for your suggestion.
Yes, I love to customise Linux.
I am making a backup.
That is good,
and I think its great you're using multiple desktops, makes you get more acquainted with the system and environment. Perhaps you can teach or learn us something when you get to know them better.
Now I am having an account problem. After some time I will create a topic on that.
It has success removed qt5 but still, the application style is not opening. The topic has not solved...
Please help...
Hello @Aravisian sir
My problem is still not solved. That command has removed the qt5 but still, the application style setting is not opening.
Please help...
Are you running KDE on Zorin OS?
Yes, I am using the kde plasma desktop environment in Zorin os.
Ok, I have tried KDE many times... I have never used KDE.
I will need to research this.
Okay, sir. Thank you, I am waiting.
Actually, I have also searched this but I don't get any results but I think you can because you know what to search better than me.
...I wouldn't bank on it...
Sorry sir, I can't understand...
Do you get any results?
I have not, yet, sorry.
I have been very busy here and will be for some time, yet.
I can pop in and give a brief comment before running off again...
What I meant earlier is that I am notorious for not knowing the right search terms.
oh okay
i was just saying that because you have better knowledge of Linux from me
People actually laugh at me because I can miss a search term on repeated searches.
I will try a search, find something... Then when I go to search it later to show someone, can suddenly no longer find it no matter what I try. It's a bit embarrassing...
Why you are doing your insult by yourself ?
you are a nice person.
Honesty is nice.![]()
