System setting crashes after opening the application style
system setting crashes after opening the application style. this is not once, every time I try to open the application style the system setting crashes.
now I am in the kde plasma desktop environment.
2021-12-22_09-06_1
please help
Hello,
@Aravisian
@100WCharge
@dasjdoom
@anon96359095
@StarTreker
@FrenchPress
Please help
Try using Synaptic to remove qt5-styleplugins
based on advice from [Solved] Cannot open "Application Style" in KDE system settings. / Applications & Desktop Environments / Arch Linux Forums
How to install Synaptic
Did you click the first link? Instructions are in there.
Or just use sudo apt remove qt5-styleplugins
Wait I can install that with apt
Sir, I have done that.
Sir, I can't able to understand what is coming on the terminal. It is taking a very long time.
@carmar please help me
Close either terminal or synaptic- don’t have both open. Remove the package only using one method.
sir it is saying
E: Unable to locate package qt5-styleplugins
2021-12-22_10-42
I suggest clicking the “report bug” button for now.
Someone else may be able to help you, shortly.
i have already done that but my bug was not uploading. i have tried 3 times to upload but still not uploading.
is there any way to do this with synaptic package manager?
If that package is not installed then it’s not installed - synaptic won’t show anything different from the terminal.
That package may not be the cause of the bug. May be something else. I couldn’t find anything else from websearching - you may have better luck.
i have also searched a lot but i didn't get anything useful. thanks for tying to help me.
hello, can you help me
@Aravisian
@100WCharge
@dasjdoom
@anon96359095
@StarTreker
@FrenchPress
Hellođź‘‹, please help me...
AdarshMeher,
perhaps you should wait for someone who's well known with the Plasma environment. I believe Swarfendor437 has KDE installed and can tell you more about the problem.
But if you are using Zorin with multiple desktops, isn't it possible to enter the Gnome environment for the time being. Using the gear icon when before you login.
@AdarshMeher, have some patients please! people are volunteers on this forum.
@swarfendor437 is a kde specialist in my eyes, maybe we have to wait for him.
Okay sir, I am waiting.
I believe it is
sudo apt remove qt5-style-plugins
I am sorry. I can't able to see this message tomorrow. Please wait some time I am trying this.
