I get that a lot of people only are on single user machines but when you've got a shared family computer and you press shutdown and nothing happens its infuriating, this is also a usability issue that made me switch from elementary os to try zorin. For a while it seemed to work. Now it isn't
however now it isn't. Yes I've paid for pro. Its not a big ask but please, when I press shutdown I want the machine to shutdown, not tell me someone else is logged in and then proceed to do nothing.
Pretty please tell me how I can set this to the default or at least a second option to force shutdown.
Arrow key to the bottom and add the line: KillUserProcesses=yes
Tap ctrl+o to overwrite, then enter to save, tap ctrl+x to exit the editor. Now, create a new configuration file for your multi-user computer:
Again: Tap ctrl+o to overwrite, then enter to save, tap ctrl+x to exit the editor.
What this should do is prevent systemd from halting shutdown if users do not fully log out.
If a user is not fully logged out when you go to shutdown, it should log them out.
You will need to reboot once for the changes to take effect.
You can use systemctl poweroff -i which will ask for your password.
Ok tried it out and it asked for my password. This is not doable as my kids aren't admins, they need to be able to shutdown the pc without entering a password.
