Is it possible to move the taskbar icons closer together? I'd like for them not to be so spread out. I have them centered and I'm using the Win 11 style appearance.
@dwyndal , your profile lists Pro, Core and Lite. The answer to your question is dependent on which edition you are using.
This is because Core uses Gnome and Lite uses XFCE, which are different desktop environments and manage their panel applets differently.
Can you please clarify which desktop you are seeking to adjust?
I'm using Pro.
We need to know if you are using Pro Core or Pro Lite to give any kind of helpful advice.
I'm using Pro Core 16.2
