I'm fairly new to Zorin OS, so far I enjoy the experience coming from Windows 10.
What I'm experiencing is an issue with the taskbar, where the background applications that start with the OS are not visible. For example I installed Flameshot with the software manager, and with the Startup Applications app. The command to start it is: /usr/bin/flatpak run --branch=stable --arch=x86_64 --command=flameshot org.flameshot.Flameshot.
Thing is, this worked a few days ago, and after some update of the system, it stopped showing up in the taskbar. The process is running, I can see it under processes, but it does not come to focus (even ALT + Tab). I can't get to the UI of Flameshot. The same goes for DropBox and NextCloud.
So I doubt it's a Flameshot thing only.
Here is my machine info from neofetch:
OS: Zorin OS 16.1 x86_64
Host: 81YQ IdeaPad 5 15ARE05
Kernel: 5.13.0-39-generic
Packages: 2922 (dpkg), 47 (flatpak),
Shell: bash 5.0.17
Resolution: 1920x1080
DE: GNOME
WM: Mutter
WM Theme: ZorinBlue-Dark
Theme: ZorinBlue-Dark [GTK2/3]
Icons: ZorinBlue-Dark [GTK2/3]
Terminal: gnome-terminal
CPU: AMD Ryzen 7 4800U with Radeon G
GPU: AMD ATI 03:00.0 Renoir
Memory: 2221MiB / 15358MiB
I rebooted the laptop a few times, and It got working again, but then in the next reboot it's not.
What I can see in my logs:
22:40:55 systemd: Failed to start Application launched by gnome-session-binary.
22:40:53 systemd: Failed to start Application launched by gnome-session-binary.
22:40:52 gdm-session-wor: gkr-pam: unable to locate daemon control file
22:40:45 smartd: Device: /dev/nvme0, number of Error Log entries increased from 2736 to 2738
22:40:43 kernel: integrity: Problem loading X.509 certificate -65
I know this is not the solution, but to quickly see what's running, I use the hot corners for this. Moving the mouse up to the left upper corner. show all the applications in use, even though they don't show on the taskbar.
If you're using core, you could also look in the taskbar settings and see if the option > " Show running applications" is turned on.
I just removed the Flameshot from the startup applications, and now I really wonder how I managed to add it in there at all, since I didn't type usr/bin/flatpak run --branch=stable --arch=x86_64 --command=flameshot org.flameshot.Flameshot, I do remember selecting the application from a list.
Can't reproduce this now. Anyway, Flameshot works now when I start it manually, so I will leave it at that - no autorun for now.
Yes, this was on the whole time.
I would say let's close this topic for now. Might be a fault on my side with how I added the apps to the Startup Applications.
