Taskbar problem
Hi!
I have a problem when it comes to my taskbar. Some things just disappear and dont fit at all when i download shell extensions.
The red arrows are where it does not fit and it does have a lot of space left. My question would be, how do i solve this problem so all my extensions is visible?
Do you have some sort of tweak or addon installed? Your date/time, etc., do not look like any appearance I recognize.
some addons are installed yes and i have just extend the date and time. does not matter if i turn this off or uninstall, same thing happens.
When you uninstall the addons remove their configuration files as well using either Synaptic (complete removal option) or sudo apt purge <addon name> (terminal).
You can also try reinstallation of these packages (if the above suggestion doesn’t fix the problem): gnome-shell-extension-zorin-taskbar and gnome-shell-extension-zorin-panel - I recommend using Synaptic to do that.
