i remember customizing it to my liking the previous day,however, I only changed the colors, installed rust on my pc and it does not open
Clear custom command in the terminal settings should fix it.
Why did You installed Rust on Your PC? Was it for Your Terminal Customization? And the Terminal: Is it the default Terminal? Looks different for me.
Mod note:
Simplified the title and moved the description into the main body of the post.
