Terminal visual artifact: Duplicate APT progress lines when maximizing/resizing window on Zorin OS 18.1 (X11)
Hello Zorin OS Team and Community,
I have encountered a consistent visual rendering bug (artifact) in the default Terminal application while performing system updates. I would like to report it so it can be investigated.
Bug Description:
When running an update command (such as sudo apt upgrade), the dynamic progress bar/percentage text (colored in orange/yellow) duplicates itself if the Terminal window is maximized or resized during the download/installation process.
For example, if the progress is at 67% and I click the maximize button, the "67%" line freezes and stays printed on the screen as a visual ghosting artifact. Meanwhile, a new line is created right below it to correctly resume displaying the progress (68%, 69%, etc.). The system updates perfectly fine in the background, but the UI terminal output creates messy duplicate lines.
Steps to Reproduce:
  1. Open the default Terminal.
  2. Run sudo apt update && sudo apt upgrade (with pending updates).
  3. Wait until the colored progress lines appear showing percentages.
  4. Click the "Maximize" window button or manually resize the window.
  5. Notice that the old progress line freezes, and a duplicate active line appears below it.
System Specifications (Verified via terminal):
  • OS: Zorin OS 18.1 (64-bit)
  • Windowing System: X11
  • Kernel version: Linux 7.0.0-28-generic
  • Hardware Vendor: ASUSTeK COMPUTER INC.
  • Hardware Model: X555QA
  • Firmware Version: X555QA.325
Thank you for your amazing work on Zorin OS. I hope this technical feedback helps improve the desktop experience!
Best regards,
Anass
Could You add Your Hardware Specs, too please? I mean CPU, GPU, RAM etc.
