Cannot launch Terminal (gnome-terminal) all of a sudden. Nothing manually was done really that I can think of. Tried following this article but cannot login in tty mode with my main account. Just a quick flash of a new screen (error message?) then back to tty login prompt.
Using another terminal (guake, Terminated) renders the same result = won't start.
Created a new admin account and the terminal app works so there's def something with my main account. Ideas?
It could have been a corruption in the saved settings used for the Terminal Emulator. Perhaps a save didn't write properly. Or a configuration caused a conflict in the running of the terminal.
I use Oh-My-Zsh, instead of fish, actually...
It's only annoying issue is when it connects to git -which I prefer disabled. It really delays terminal launch.
Generally, checking the ~/.config is the First Stop solution for most. Isolating it to the package as you did is even better. Sometimes, there's no telling what went wrong in the configs. But you key clue was that it worked on another account.
