Hello Zorin Community,
I'm a long time Windows user and not that knowledgable about informatics. I really wanted to try out Zorin since it seemed user-friendly and easy to install, but here I am struggling with the installation.
Here are my specs:
Acer Aspire 5 (A515-55-50QW)
Intel i5-1035G1
16GB RAM
512GB SSD
no OS installed except eShell (Linux)
I flashed my USB-drive with Balena Etcher and booted from usb which has worked until I needed to specify the partitions for installation:
Since I have a UEFI-based system (I believe) I first created a EFI System Partition with 512 MB in size and then a Ext4 journaling file system with 20000 MB and Root partition (/). After continuing an error appears on the next screen:
"the efi file system creation in partition failed"
I tried a lot of variations but I can't get passed the partition part.
Would be really glad if anyone got a solution for this problem.
Cheers,
Tetsu
