Could You maybe add in the Future Icons for:
- fre:ac
- Popsicle
- Amberol
Sure.
I have a Question: I looked in the Folders of the Icon Set for the Logo of Your Icon Set (the one with the 2 toned Stones). I tought it would be nice to have it as a Startmenu Button. So I searched but unfortunately didn't found it. Maybe I simply oversaw it. Can You say me in what Folder it is? I mean this one:
Oh, it aren't in the theme. I just used it as logo. But here you are. I don't have it as .svg anymore.
Thank You, I will see if it works like it is. If not I try to convert it to .svg.
EDIT: I could it directly save as an .svg File. So, all is good. Thank You again.
Hello, again!
I want ask if you could add in a Future Update Icons for the Dconf Editor and Impression.
And there is a minor Thing what I saw. When I use the Software Updater and there are Updates for the System marked as Zorin OS there is an Solus Icon:
Could you maybe change that to a neutral Icon - like Your Icon Set Logo with the Stones? Or could You say me how this Icon is called? Then I could try to change it by myself and You don't need to care about that.
I'll take a look at it.
I guess you have to do it by yourself - the icon package when extracted spits out errors and only the half of the icons is there, sorry. I'm not sure what's wrong.
I think the icon you're looking for is in Places folder.
Okay, thank you for the Info. I will try it. And if it works I will let you know. But Icons for Impression and the Dconf Editor are makeable?
To give You a quick Update to this:
It worked. It was in the places Folder like you wrote. It was an Icon called distributor-logo.svg and I renamed Your Icon Set Logo with this Name. Then I went to the subfolders 16, 22, scalable and scalabe@2 and deleted the Icons there and replaced them. But before this I canged the Icon Set to a Zorin Set to avoid Real-Time Issues.
Version 1.6 --> 1.8 is out!
Added: Heroic Game Launcher, LibreWolf, Lutris,
Added: conky, Grub Costumizer, Meld, Vim,
Added: Wayland, Xorg, Yad,
Added: Freetube, keepassXC, Mullvad VPN, Mullvad Browser,
I have a quick Question to Your new Version: Did you changed Icon Sizes? I posted above a Picture from ClamTk and there have the Icons more or less the same Size. But now with Version 1.8 it looks that:
The Icons in Row 1 Position 4, Row 2 Position 1, Row 4 Position 1 are bigger than before.
Nope. I haven't changed the size.
Hmm ... okay.
I found this:
In your index.theme File are 3 Folders for actions:
But there are only 2 Folders included:
I will take a look on an older Version if it is there like this, too. But I have to search trought my USB Sticks.
I'm re-writing and rebuilding the icon theme, but I can't promise the new version will be Gnome compatible, so backup the current one.
Applications themselves determine whether they will call upon the regular icon or the symbolic icon.
Many will decide what size of icon to display or whether to default to the system values.
This can be infuriating to icon creators like myself or Storm, when an update breaks our stuff because that application developer wanted to seize control.
As an icon creator, I worked around this by disallowing having different looking Symbolic icons and making the entire set uniform in appearance. Yes, this does defeat the purpose of Symbolic Icons which are supposed to be exceptionally simple and straightforward - but that purpose was already defeated by application developers deploying them when they shouldn't.
Then I tightened the sizing in my index.theme file.
Again - another example of lack of Polish in Gnome, due to the Gnome Developers decisions (In this case). Yet, most people parrot about how polished it is because that is what everyone else says about it.
Upcoming version 2.0 in a near future. Remade the icon theme from scratch.
Almost done. I just need to make the preferences icons (used in KDE apps and settings). Then I also need to test it on different distro and DEs before releasing it.
