Thunar Customisation to match Zorin core's look and feel
Due to some inconsistency in Zorin lite, I have switched to Zorin core. But missing some of the things from Lite, like it's file manager Thunar for this topic. Getting it under Core everything works good except it's UI, which doesn't match to Core's design language. So I made some customization to match the look and feel as close as possible. And have succeeded on the most of the part.
Here are the results:
Now the problem is, when I'm using it in ~/.config/gtk-3.0/gtk.css, it doesn't respect the changes when I switch the dark/light mode in the desktop. So to workaround this I made the light and dark variant of my customization and added them to the respective gtk.css of Light and Dark variants of my preferred theme (ZorinBlue). Everything works good, it changes when I switch between theme modes, except the following part:
The text colors of the selected item isn't applying the color that I have added through my customization (compare it with the first set of images, to know the difference). Anyone have clue, why it happens? and how to fix it?
Contents of the customization:
Light variant
/*Thunar sidebar customization*/
.thunar
  .sidebar.frame.shortcuts-pane
   .view {
  border-radius: 15px;
	padding-top: 10px;
	padding-bottom: 10px;
	padding-left: 2px;
	padding-right: 2px;
	background-clip: padding-box;
.thunar
  .view:hover {
	background-color: rgba(0, 0, 0, 0.1);
	border-left: 2px solid transparent;
	border-right: 2px solid transparent;
	border-top: 1px solid transparent;
	border-bottom: 1px solid transparent;
.thunar
  .view:selected {
	color: white;
	background-image: linear-gradient(to right, #059feb, #1fc0fb);
/*Thunar List view customization*/
.thunar
 .frame.standard-view
  .view {
	/*background-color: rgba (235, 247, 255, 0.1);*/
	padding: 15px;
	font-size: 15px;
.thunar
  .view:hover {
.thunar
  .view:selected {
	background-color: rgba(21, 166, 240, 0.3);
	color: rgb(18, 51,84);
Dark Variant
.thunar
   .view {
	padding-top: 10px;
	padding-left: 2px;
	padding-right: 2px;
.thunar
  .view:hover {
	background-color: rgba(255, 255, 255, 0.1);
	border-left: 3px solid transparent;
	border-right: 3px solid transparent;
.thunar
  .view:selected {
	color: rgba (0, 0, 0, 0.8);
	background-image: linear-gradient(to right, #bde6fb, #bde6fb);
.thunar
  .view {
	background-color: #161e1f;
	padding: 15px;
	font-size: 15px;
.thunar
  .view:hover {
.thunar
  .view:selected {
	background-color: #50636d;
	color: rgba (255, 255, 255, 0.9);
dark variant for example color code typo
change it to
color: rgba(255, 255, 255, 0.9);
in whiite vesion you made a typo for color:
rgb(18, 51,84);
change it to
color: rgba(18 , 51, 84);
and try to respect css codification (space and no space), css is flexible but better respect it
Thanks @Nourpon for pointing out the typos and spaces. I fixed those now but the results are still same.
I'm not getting the desired text colors on selected item.
try to replace your color with red only like this
color: red;
you will se if it affect the right element
The thing is when I'm using it in ~/.config/gtk-3.0/gtk.css the colors are affecting as desired. But when I add those in /usr/share/themes/ZorinBlue-Light/gtk-3.0/gtk.css , only the text color is not applying.
because you can't affect Zorin theme like you want, many keys are hard coded in their theme, you can try to add !important in your code like this
color: red !important;
maybe it can work
Still same
Are there any other ways to achieve the same behavior, so when I switch between light and dark mode it automatically apply my custom light or dark variant according to system?
