My panel in zorin is not visible. Presently, my panel looks like this.
But when I open some application like chrome or some other thing the panel turns to white. How can I get the white panel all the time. I want my top panel to look like this.
Are you using core or light of Zorin OS?
I believe that is Zorin Ultimate core.
Open the Zorin Appearance app and then navigate to the Panel tab. Then disable Dynamic Background Opacity
It'll make it so that the status bar remains opaque. Hope this helps.
