Hello,
After using Zorin for the past few months on VM and dual boot, I finally decided to burn the bridge, and install it bare metal (?) on my primary.. Lenovo Ideapad 330. Installation went fine, everything worked. Installed all apps and set everything else up.
And then this happened:
Restarted, logo and zorin screen appeared, grub screen (?) appeared, but then it's stuck at "TOPAZ not supported in kfd".
I tried restarting, and I also set the BIOS to default. Same result. I did some googling but it seems beyond my comprehension, as I'm new to Linux. It might be a conflict with the AMD GPU of some sort?
I read a suggestion to "update BIOS", and I.. don't know how to do that, as all BIOS seem different and even the Lenovo help site uses a different BIOS than mine.
I've installed Zorin as a single OS on a 7 year old ASUS before, and it works fine. So safe to assume its a hardware conflict with my primary Lenovo.
Any help would be greatly appreciated!
