Hello,
I bought a Topton L4 umpc and the only thing that didn't work with the zorin install of 16 is the WiFi device. It doesn't even show in the hardware so it's obviously not supported. I did a search in the forums here but wasn't able to find an answer.
Topton L4 is mini-laptop with a 7 inch display, 8GB of RAM, and $299 starting price
Est. reading time: 4 minutes
If anyone knows more than me, there is a good chance that 99.99% of you do, maybe you would know how to get the WiFi working on it?
Hello and welcome to the forum
Could please issue this command in terminal and copy/paste the output?
lspci
I'll have to manually type it into the browser as that copy/paste won't work because the WiFi doesn't work.
From your keyboard
ctrl + alt + T
to open terminal.
The type,
lspci
Yeah... those commands won't work. Thanks though. Still working on the other computer and will have to hand create the output since the WiFi isn't working on the laptop in question.
Oh nelly that's a lot of output. Maybe a screenshot would be better?
A screen shot will not be useful.
Please select the whole output and copy and paste in your reply.
I'm guessing you're not understanding the point of the WiFi not working. How would I copy/paste into my reply when it's on another machine that is having an issue with its WiFi connection? Perhaps I should adjust my earlier value of 99.99% to 99.98%
Copy and paste the output into a text file.
Save it on a USB key.
Copy the text file from the USB key to a machine with WiFi connection.
Unless you have no spare USB key, the above scheme should work.
It took me a bit but I was able to find and borrow my kids thumb drive.
00:00.0 Host bridge: Intel Corporation Celeron N3350/Pentium N4200/Atom E3900 Series Host Bridge (rev 0d)
00:00.1 Signal processing controller: Intel Corporation Device 5a8c (rev 0d)
00:02.0 VGA compatible controller: Intel Corporation HD Graphics 500 (rev 0d)
00:0e.0 Audio device: Intel Corporation Celeron N3350/Pentium N4200/Atom E3900 Series Audio Cluster (rev 0d)
00:0f.0 Communication controller: Intel Corporation Celeron N3350/Pentium N4200/Atom E3900 Series Trusted Execution Engine (rev 0d)
00:12.0 SATA controller: Intel Corporation Celeron N3350/Pentium N4200/Atom E3900 Series SATA AHCI Controller (rev 0d)
00:15.0 USB controller: Intel Corporation Celeron N3350/Pentium N4200/Atom E3900 Series USB xHCI (rev 0d)
00:16.0 Signal processing controller: Intel Corporation Celeron N3350/Pentium N4200/Atom E3900 Series I2C Controller #1 (rev 0d)
00:16.1 Signal processing controller: Intel Corporation Celeron N3350/Pentium N4200/Atom E3900 Series I2C Controller #2 (rev 0d)
00:16.2 Signal processing controller: Intel Corporation Celeron N3350/Pentium N4200/Atom E3900 Series I2C Controller #3 (rev 0d)
00:16.3 Signal processing controller: Intel Corporation Celeron N3350/Pentium N4200/Atom E3900 Series I2C Controller #4 (rev 0d)
00:17.0 Signal processing controller: Intel Corporation Celeron N3350/Pentium N4200/Atom E3900 Series I2C Controller #5 (rev 0d)
00:17.1 Signal processing controller: Intel Corporation Celeron N3350/Pentium N4200/Atom E3900 Series I2C Controller #6 (rev 0d)
00:17.2 Signal processing controller: Intel Corporation Celeron N3350/Pentium N4200/Atom E3900 Series I2C Controller #7 (rev 0d)
00:17.3 Signal processing controller: Intel Corporation Celeron N3350/Pentium N4200/Atom E3900 Series I2C Controller #8 (rev 0d)
00:18.0 Signal processing controller: Intel Corporation Celeron N3350/Pentium N4200/Atom E3900 Series HSUART Controller #1 (rev 0d)
00:18.1 Signal processing controller: Intel Corporation Celeron N3350/Pentium N4200/Atom E3900 Series HSUART Controller #2 (rev 0d)
00:18.2 Signal processing controller: Intel Corporation Celeron N3350/Pentium N4200/Atom E3900 Series HSUART Controller #3 (rev 0d)
00:18.3 Signal processing controller: Intel Corporation Celeron N3350/Pentium N4200/Atom E3900 Series HSUART Controller #4 (rev 0d)
00:19.0 Signal processing controller: Intel Corporation Celeron N3350/Pentium N4200/Atom E3900 Series SPI Controller #1 (rev 0d)
00:19.1 Signal processing controller: Intel Corporation Celeron N3350/Pentium N4200/Atom E3900 Series SPI Controller #2 (rev 0d)
00:19.2 Signal processing controller: Intel Corporation Celeron N3350/Pentium N4200/Atom E3900 Series SPI Controller #3 (rev 0d)
00:1b.0 SD Host controller: Intel Corporation Celeron N3350/Pentium N4200/Atom E3900 Series SDXC/MMC Host Controller (rev 0d)
00:1c.0 SD Host controller: Intel Corporation Celeron N3350/Pentium N4200/Atom E3900 Series eMMC Controller (rev 0d)
00:1e.0 SD Host controller: Intel Corporation Celeron N3350/Pentium N4200/Atom E3900 Series SDIO Controller (rev 0d)
00:1f.0 ISA bridge: Intel Corporation Celeron N3350/Pentium N4200/Atom E3900 Series Low Pin Count Interface (rev 0d)
00:1f.1 SMBus: Intel Corporation Celeron N3350/Pentium N4200/Atom E3900 Series SMBus Controller (rev 0d)
I read through the output.
I could not see any WiFi module listed.
Just an off shot, do you see any physical switch (or a spcial key) on your machine to enable/disable network?
Also check if you are not in airplane mode.
FYI, the machine has w10 preinstalled. I'm using the zorin live usb* environment to test things out before commiting. Yes, the WiFi works fine under windows 10. There is no physical switch (good idea though).
*(My usb drive was being used already which is why I had to go find another)
Lucky you have a resourceful kid.
I wish I have one
My biggest fear is that this WiFi module is designed to work only in Windows. I have encountered couple of such devices in past.
Is it possible for you to boot into Windows and open Device Manager and jolt down the property of this WiFi module? That would facilitate our trouble shooting a lot.
emaildave:
eMMC Controller
Oops, I did not notice that...
It's listed as...
Realtek 8821CU Wireless LAN 802.11ac USB NIC
Meaning? It's too "C.r.a.p.p.y"???
I am afraid it is not included in Linux kernel.
You have to compile its driver from the source.
Oh fun.
Never done a recompile before.
Hello Mr Google, table for one... Go ahead and help your other customers as I'm going to be here for a while.
