Is anyone successfully using a touchscreen and pen with Zorin 17? If so what hardware is it working with?
I have an older ThinkPad that uses Wacom technology and while touch and pen work when the system is first set up, they do not work at all once the computer is shut down and restarted. This also happens with Mint. Debian works fine, so it is probably something with Ubuntu based distros.
I have another ThinkPad with Wacom touch and pen, and an HP Spectre 360 with touchscreen and an active pen that will not upgrade to Windows 11. I can repeat the same process, testing to see if things work, or I can just stick with Debian as it does seem to handle this better. I just prefer the environment in Zorin.
You can install the Zorin OS themes and extensions on Debian with Gnome. I mention this as an option - as it is open source.
Now, you do need to match the Gnome Version - so first check which Gnome you are using... Zorin OS 17 is on Gnome 43
In that case, you can use the Zenith themes, which are a vetted Zorin-based theme for use on Cinnamon Desktop environments.
I have not made the Light Themes, so only available is
zenith-blue-dark
zenith-green-dark
zenith-grey-dark
zenith-orange-dark
zenith-purple-dark
zenith-red-dark
Possibly. Wacom and Wayland have a variety of issues, which Zorin OS 17 introduced defaulting to Wayland. There are device detection issues after reboot for some ThinkPads using integrated Wacom hardware.
Wacom tablet support on Wayland is not as mature as on Xorg, and some users report that their devices stop working after suspend/reboot.
