Hi,
This is my first post on the Zorin forum. Not sure if I posted it in the right category. I have a Surface Pro 9 running windows 11. I tried installing Zorin 16.3 and everything with the USB install worked smoothly. However, when it opened to the try/install page, the touchpad and keyboard didn’t work. I currently don’t have a mouse / keyboard that I can connect via USB. Can I fix this? I’ve had to force a reset to Windows several times by now.
You likely need to install the Surface Linux Kernel:
