I'm using a Ideapad S145 laptop, running the lastest linux kernel
I've tried :
Installing synaptics
Updating the kernel
GRUB_CMDLINE_LINUX_DEFAULT="i8042.reset quiet splash"
And none worked
I've tried :
Updating the kernel
And none worked
This seems to be an issue with this specific model. Lucky for you, it has already been fixed.
Check out this Github repo and follow the instructions to apply the kernel module update.
Let us know if you need more help.
Didn't work
That's very odd... it should work. Can you verify that you did it correctly?
Here are the steps to fix it:
It's working fine now!
worked with my Lenovo IDEAPAD 3. Thanks guys!
