Device 'ETPS/2 Elantech Touchpad':
Device Enabled (164): 1
Coordinate Transformation Matrix (166): 1.000000, 0.000000, 0.000000, 0.000000, 1.000000, 0.000000, 0.000000, 0.000000, 1.000000
Device Accel Profile (294): 1
Device Accel Constant Deceleration (295): 2.500000
Device Accel Adaptive Deceleration (296): 1.000000
Device Accel Velocity Scaling (297): 12.500000
Synaptics Edges (298): 59, 1421, 39, 701
Synaptics Finger (299): 1, 1, 0
Synaptics Tap Time (300): 180
Synaptics Tap Move (301): 72
Synaptics Tap Durations (302): 180, 180, 100
Synaptics ClickPad (303): 0
Synaptics Middle Button Timeout (304): 75
Synaptics Two-Finger Pressure (305): 282
Synaptics Two-Finger Width (306): 7
Synaptics Scrolling Distance (307): 33, 33
Synaptics Edge Scrolling (308): 0, 0, 0
Synaptics Two-Finger Scrolling (309): 1, 0
Synaptics Move Speed (310): 1.000000, 1.750000, 0.120919, 0.000000
Synaptics Off (311): 1
Synaptics Locked Drags (312): 0
Synaptics Locked Drags Timeout (313): 5000
Synaptics Tap Action (314): 2, 3, 0, 0, 1, 3, 2
Synaptics Click Action (315): 1, 1, 0
Synaptics Circular Scrolling (316): 0
Synaptics Circular Scrolling Distance (317): 0.100000
Synaptics Circular Scrolling Trigger (318): 0
Synaptics Circular Pad (319): 0
Synaptics Palm Detection (320): 0
Synaptics Palm Dimensions (321): 10, 200
Synaptics Coasting Speed (322): 20.000000, 50.000000
Synaptics Pressure Motion (323): 30, 160
Synaptics Pressure Motion Factor (324): 1.000000, 1.000000
Synaptics Resolution Detect (325): 1
Synaptics Grab Event Device (326): 0
Synaptics Gestures (327): 1
Synaptics Capabilities (328): 1, 0, 1, 1, 1, 1, 1
Synaptics Pad Resolution (329): 31, 31
Synaptics Area (330): 0, 0, 0, 0
Synaptics Noise Cancellation (331): 8, 8
Device Product ID (291): 2, 14
Device Node (290): "/dev/input/event6"
Some say that the xorg drivers work better than Libinput for this device:
sudo apt install xserver-xorg-input-synaptics
just copy and paste in terminal? Or its necessary to remove the old version? Because nothing happend...
If already installed... Then that may not be the helpful solution.
I restored to searching the web on this (Elantech is notorious...):
This user suggests it is a BIOS Setting (So may work on some computers)
the link describes only the function to disable the touchpad by using FN and F7.... it doesnt change anything... thanks for your help.
How can i deinstall the function, cause the touchpad isnt reliable anymore....
replace 'install' with 'remove' in the command that Aravisian posted.
