New here, just installed zorin on an old Surface 2. Trying to get away from windows before EOL suppt for windows10. I have lots to learn. It seems that for the most part its functional, theres some weird stuff with the touchscreen and keyboard and Touchpad too, but for the most part it seems to work. I was curious if there is a way to install a more touch friendly or mac/ios like theme.
Have a look in the Zorin Appearance settings see if anything suits.
yeah the bottom right theme is close, but it needs to be a constant dock thing
You mean this Layout:
If yes and You want to add a Dock to the Desktop, You could use the Gnome Extension Das To Dock. Then You have a Dock.
