ditto
March 24, 2026, 12:50am
1
So I have a secondary monitor (asus proart touchscreen) and it was initially working just fine. It would track my finger inputs and basically just work like you'd expect. Randomly one day, it stopped working. I have tried multiple troubleshooting solutions found on this forum but none worked...so far at least.
Here's the weird thing, using multi finger gestures such as three finger swipes works. It is only single finger touch that doesn't seem to register. So I know the screen is picking up the touch but for some reason, refuses to work with single finger input.
Has anyone had this problem and/ or know of a solution? My Zorin Desktop is utilizing x11, not wayland.
Could be another case of the dreaded update to 6.17 kernel. Suggest you test by booting an older 6.14 kernel.
Do a Restart
then from grub menu item "Additional Options for Zorin".
select a 6.14...kernel generic version.
Boot that and test.
Can you relay the terminal output of:
libinput list-devices
and
xinput list
I wonder if LibInput is treating it as a mouose, rather than touch on display.
ditto
March 25, 2026, 2:11am
5
Thanks. Just tried this but it did not work unfortunately. Same results. Single finger touch (dragging and selecting) doesn't work but multi-finger function somehow.
I even tried timeshifting back to the earliest save, but no luck there either.
I am totally stumped as to what could be causing this issue...but if you or anyone have any other suggestions or ideas it would be very much appreciated!
ditto
March 25, 2026, 2:15am
6
here are my outputs below
libinput list-devices:
Device: Power Button
Kernel: /dev/input/event1
Group: 1
Seat: seat0, default
Capabilities: keyboard
Tap-to-click: n/a
Tap-and-drag: n/a
Tap drag lock: n/a
Left-handed: n/a
Nat.scrolling: n/a
Middle emulation: n/a
Calibration: n/a
Scroll methods: none
Click methods: none
Disable-w-typing: n/a
Disable-w-trackpointing: n/a
Accel profiles: n/a
Rotation: 0.0
Kernel: /dev/input/event0
Group: 2
Tap-to-click: n/a
Tap-and-drag: n/a
Tap drag lock: n/a
Left-handed: n/a
Nat.scrolling: n/a
Calibration: n/a
Click methods: none
Accel profiles: n/a
Rotation: 0.0
Device: ELAN Touchscreen
Kernel: /dev/input/event18
Group: 3
Capabilities: touch
Tap-to-click: n/a
Tap-and-drag: n/a
Tap drag lock: n/a
Left-handed: n/a
Nat.scrolling: n/a
Calibration: identity matrix
Click methods: none
Accel profiles: n/a
Rotation: 0.0
Device: Logitech G502 HERO Gaming Mouse
Kernel: /dev/input/event2
Group: 4
Capabilities: pointer
Tap-to-click: n/a
Tap-and-drag: n/a
Tap drag lock: n/a
Left-handed: disabled
Nat.scrolling: disabled
Middle emulation: disabled
Calibration: n/a
Scroll methods: button
Click methods: none
Accel profiles: flat *adaptive custom
Rotation: 0.0
Device: Logitech G502 HERO Gaming Mouse Keyboard
Kernel: /dev/input/event3
Group: 4
Capabilities: keyboard pointer
Tap-to-click: n/a
Tap-and-drag: n/a
Tap drag lock: n/a
Left-handed: n/a
Calibration: n/a
Click methods: none
Accel profiles: n/a
Rotation: 0.0
Device: Corsair Corsair Gaming K55 RGB Keyboard
Kernel: /dev/input/event4
Group: 5
Tap-to-click: n/a
Tap-and-drag: n/a
Tap drag lock: n/a
Left-handed: n/a
Calibration: n/a
Click methods: none
Accel profiles: n/a
Rotation: 0.0
xinput list:
⎡ Virtual core pointer
id=2
[master pointer (3)]
⎜ ↳ Virtual core XTEST pointer
id=4
[slave pointer (2)]
⎜ ↳ Logitech G502 HERO Gaming Mouse
id=8
[slave pointer (2)]
⎜ ↳ Logitech G502 HERO Gaming Mouse Keyboard
id=9
[slave pointer (2)]
⎜ ↳ Corsair Corsair Gaming K55 RGB Keyboard
id=10
[slave pointer (2)]
⎜ ↳ ELAN Touchscreen
id=13
[slave pointer (2)]
⎣ Virtual core keyboard
id=3
[master keyboard (2)]
↳ Virtual core XTEST keyboard
id=5
[slave keyboard (3)]
↳ Power Button
id=6
↳ Power Button
id=7
id=11
id=12
It is correctly recognizing it...
Can you run
sudo libinput debug-events
Then tap the display with one finger and relay what the terminal prints?
ditto
March 25, 2026, 2:21am
8
Yes, I actually tried this earlier and it does give me outputs as I touch the screen.
When I touch the screen it gives:
event 18 TOUCH_FRAME
event 18 TOUCH_MOTION
then of course, all the coordinates beside those events.
Recognized and working...
What about
xrandr --listmonitors
ditto
March 25, 2026, 2:26am
11
0: +*DP-4 3840/890x1600/390+1920+0 DP-4
1: +HDMI-0 1920/309x1080/174+0+0 HDMI-0
HDMI-0 is the touchscreen
Ok, let's try mapping the action to that monitor:
xinput map-to-output "ELAN Touchscreen" HDMI-0
Then touch screen with a tap to test.
ditto
March 25, 2026, 2:29am
13
Just tried that and nothing happens when I tap.
Sigh.... I know that Gnome really wants us on Wayland.
And I know that Gnome Desktop can intercept touch events.
And I know that Gnome is providing a desktop that "encourages" using Wayland by "breaking things in X11" that always worked before.
Have you tested if it does work on Wayland?
Otherwise...
ps aux | grep -E "gesture|libinput|fusuma"
And let's see if it is Gnome...
ditto
March 25, 2026, 2:40am
15
So this is what I got. Still no screen response either.
zero 49175 0.0 0.0 14768 2340 pts/2 S+ 21:35 0:00 grep --color=auto -E gesture|libinput|fusuma
Next command, lol
xinput list-props "ELAN Touchscreen" | grep "Send Events"
We can see if we can set it to the right events.
ditto
March 25, 2026, 2:50am
17
libinput Send Events Modes Available (259):
1, 0
libinput Send Events Mode Enabled (260):
1, 0
libinput Send Events Mode Enabled Default (261):
0, 0
Edit: and I forgot to say still no luck with the touch..hah
Wow.
So... The device is recognized. Driver is loaded. Events are logged. And... modes are enabled.
I am already stumped.
Turning to the internet.... I found:
sudo nano /etc/X11/xorg.conf.d/99-touchscreen.conf
Section "InputClass"
Identifier "ELAN Touchscreen as pointer"
MatchProduct "ELAN Touchscreen"
Driver "libinput"
Option "SendCoreEvents" "true"
Option "EmulatePointer" "true"
EndSection
What that is supposed to do is force it to treat single finger touch as pointer events, bypassing the problem.
Not the path /etc/X11/xorg.conf.d/99-touchscreen.conf
in case it does not work at all and you checked for typos and want to remove that configuration.
ditto
March 25, 2026, 3:22am
19
Ughh...doesn't work either. Yeah, this has been pretty frustrating to troubleshoot.
I'm out of time for tonight, but I'll see if I can find any other leads as to what may be causing this issue tomorrow.
But anyway, thanks a lot for your help.
system
Closed
June 23, 2026, 3:25am
21
