I need help uninstalling Zorin to put it on another drive but it is an OS and it is tied to my drive.
Can you please clarify your question? I am not sure I understand (I guessed your intentions for the thread title).
Just reinstall the OS on the other drive.... OS's are always tied to a drive.
I'm not really understanding what it is you're asking.
To remove Linux, open the Disk Management utility, select the partition(s) where Linux is installed and then format them or delete them . If you delete the partitions, the device will have all its space freed.
Make a back-up copy of your Zorin OS on your drive .... install Zorin on your new drive the same way you installed it on the old drive with a bootable thumb drive .... then install Zorin to the new drive after it is installed you can transfer your saved back-up copy to the new drive and delete Zorin on the other drive ....
If I understand you correctly ..... if not kindly disregard ....
